August 04, 2026, 01:12:50 pm
Hoffman Amps Forum image Author Topic: solder diameter ?  (Read 8677 times)
Offline flora
solder diameter ?
« on: June 05, 2010, 07:03:15 am »
What size solder do you guys use , .05 or .031 ?
Offline birt
Re: solder diameter ?
« Reply #1 on: June 05, 2010, 07:10:20 am »
1mm 60/40 solder
Offline SLW
    • diyeffects.com
« Reply #2 on: June 05, 2010, 07:26:45 am »
I like the 0.031 stuff.  I do build a lot of small electronics (stompboxes).
stompbox pcb's
my blog
Offline FYL
« Reply #3 on: June 05, 2010, 08:02:38 am »
0.8 mm for small jobs, 1 mm for general apps.
Go Metric, go!
Offline RicharD
    • Toxic Water
« Reply #4 on: June 05, 2010, 08:08:00 am »
.125 acid core   :huh:
Offline dynaman1
« Reply #5 on: June 05, 2010, 09:16:29 am »
.031 for me.
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #6 on: June 05, 2010, 10:26:34 am »
I use a lot of .062 for hand-wired and .032 for circuit boards and tinning.
Offline alerich
  • This one goes to 11.
« Reply #7 on: June 05, 2010, 01:37:18 pm »
Kester "44" Rosin Core    60/40    .050
Offline Shrapnel
« Reply #8 on: June 05, 2010, 01:43:10 pm »
Last solder I bought was .050. I don't really like it a whole lot thicker, and in most cases prefer smaller. (.032) BUT in cases where I need more solder per joint (i.e. ptp type work) the larger is more likable, as 6-8" extended from the spool doesn't disappear in a few seconds of soldering.
My recommendation is to let the type of soldering you do suggest the diameter. (as others have indirectly suggested.)
-Later!
Offline craneclimber
« Reply #9 on: June 06, 2010, 01:27:35 am »
last time I used that I was heating the iron on an open flame  :rolleyes:
Offline Tiny_Daddy
« Reply #10 on: June 06, 2010, 06:38:37 am »
I used .125 acid core to fix a radiator in Puerto Rico. I used an Ungar 50 watt tip. The acid dissolved the tip's iron coating but the radiator worked. Some splattered in my eye past the safety glasses and hurt like hell. Nasty stuff.
