August 03, 2026, 06:16:54 am
Hoffman Amps Forum image Author Topic: Hammond B3 Percussion Effect  (Read 6112 times)
Offline KDakaWalt
  • Fix it till it breaks
« on: June 13, 2010, 09:55:52 am »
I know there are some Hammond B3 folks here. I have been asked by a friend to look at his B3. The percussion effect is weak. It seems to be there when you activate the switch but only momentarily. I plan to replace the tubes in that section first.
I searched and found references to “hair” that can grow on some leads in this section and cause a similar problem, but no specifics.
Any help and guidance is greatly appreciated. KD
Offline GroundhogKen
  • 97.835 megatons
Re: Hammond B3 Percussion Effect
« Reply #1 on: June 13, 2010, 03:12:46 pm »
Offline topbrent
  • In pursuit of more cowbell...
« Reply #2 on: June 13, 2010, 03:18:38 pm »
Read over this so you can understand the AO-28 preamp:  http://www.bentonelectronics.com/AO28.html
Regarding zinc hair:  http://www.bentonelectronics.com/percussion.html
http://www.dairiki.org/HammondWiki/ZincDendrites
http://www.dairiki.org/HammondWiki/PercussionTroubleshooting
Check/replace the 12au7 tube associated with the percussion effect.
Since you are his repair guy now....read up on, and be prepared to rebuild the scanner someday.
-   if it isn't giving the helicopter vibrato now......it will be someday.  They all do eventually.
« Last Edit: June 13, 2010, 03:25:37 pm by topbrent »
Offline KDakaWalt
« Reply #3 on: June 13, 2010, 04:31:56 pm »
Great info! Thanks so much.  :grin:
