June 16, 2026, 08:45:17 am
Hoffman Amps Forum image Author Topic: Weak tremolo in AB763  (Read 6797 times)
Offline LooseChange
    • Fix Your Darn Amps
« on: June 21, 2010, 06:37:12 am »
Your basis tremolo circuit from the Fender AB763.
Changed the roach and the 3 caps and the tube. Everything appears to be in workinging order but the tremolo is weak. Have I missed something?  Is there a way to make the tremolo stronger.
The tremolo does not come on very quickly either.
Call me Dan
www.fydamps.com
Offline phsyconoodler
Re: Weak tremolo in AB763
« Reply #1 on: June 21, 2010, 09:58:59 am »
There is still something wrong.Those trems are as deep as can be when working properly.
  Triple check against the schematic,taking note of voltages.Double check the bias supply as a feed wire goes to the top of the trem caps.
It it takes a moment to engage,you have a ground or cap charging problem.
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: June 21, 2010, 07:02:17 pm »
There's an old thread in the Archives about tweaking the 6G16 bias-vary tremolo, but you may be able to apply some of the concepts to the roach-style tremolo:
http://www.el34world.com/Forum/index.php?topic=604.0
Is there a good way to test how well the roach is working?  IRRC there was a thread here about that not too long ago but I'm not sure.  Just because it's new doesn't mean it's good :wink:
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #3 on: June 21, 2010, 09:49:06 pm »
Change the cathode cap. Also the cap out to the Depth pot.
Offline LooseChange
« Reply #4 on: June 22, 2010, 04:47:25 am »
I'll do that but there is no cap to the Depth control.
I read in Jack Darr's book that the large resistors have to be very close to spec and that drifting up will make a difference.
« Last Edit: June 22, 2010, 04:50:50 am by LooseChange »
Call me Dan
www.fydamps.com
« Reply #5 on: June 22, 2010, 05:43:05 am »
If the cathode cap doesn't do it, try another roach. Is this an old Fender amp? If so, you may have conductive fiber board issues.
