September 19, 2026, 02:26:51 pm
Hoffman Amps Forum image Author Topic: Reverb Tank Replacement Options  (Read 7300 times)
Offline BigE
  • Fender guy...
« on: June 21, 2010, 01:34:06 pm »
Hey guys.  I've got someone that has a single spring Accutronics Reverb tank that he wants to replace with a 3 spring tank.  The code is 1DB3C1C which according to the Accutronics site correlates to this:
type 1
Input impedance 250 ohm
Output Impedance  2250 ohm
Long Decay
Input insulated/Output Grounded
No Lock
Vertical Connectors UP
I can't find a 3 spring short tank that will match the In/OUT impedance exactly.  How close/important is it to match those values?  What would YOU use for a replacement tank?
Offline phsyconoodler
Re: Reverb Tank Replacement Options
« Reply #1 on: June 21, 2010, 01:41:50 pm »
It has to match.However I've never seen a 'one spring' reverb tank.Don't you mean it has one spring left and the other one is broken off?
  The reverb won't work if the impedances don't match.
Offline BigE
  • Fender guy...
« Reply #2 on: June 21, 2010, 02:11:28 pm »
You are correct,yes.  He actually has 2 of these tanks.  They are out of a couple of Polytones.  Both have only 1 spring.  But after looking at them, 1 tank doesn't even have the little mounting clips for the second spring and the other does, but just looks like the spring has been removed.
any ideas on finding a 3 spring short with those input impedances?
Offline BigE
  • Fender guy...
« Reply #4 on: June 21, 2010, 02:48:47 pm »
Will that tank work even though the impedance values aren't exactly the same?  Psyco said they have to match or it won't work.  what's the scoop?
« Reply #5 on: June 21, 2010, 03:23:15 pm »
50 ohms in either direction should work just fine.Any more than that may not work.
  A huge difference is what i meant.250 ohms to 310 ohms is a pretty small difference.
Same with 2250 to 2575.
  It will likely work.
« Reply #6 on: June 21, 2010, 10:07:06 pm »
Changing from "8" to "1K" or "250" to "6K" will be unhappy.
Changing from 4 to 8, or 5K to 10K, or similar ratio, is unimportant. The impedance actually varies a LOT over the audio range. The sensitivity will change but you just dial-up a happy sound. And changing from a cheap 1-spring to a lush 3-spring will make more difference than a 2:1 ohms change.
