August 29, 2026, 08:52:24 am
Hoffman Amps Forum image Author Topic: Hammond M100 Ao29 on the bench  (Read 8124 times)
Offline LooseChange
    • Fix Your Darn Amps
« on: July 05, 2010, 04:21:16 pm »
I have the chassis on the bench.
http://www.hammondb3organ.net/schematics/hammond/organs/m100/m100.php?command=display&template=1&image=http://www.hammondb3organ.net/schematics/hammond/organs/m100/schem_R.JPG&descpath=/var/www/hammondb3organ.net/schematics/hammond/organs/m100/desc/schem_R.txt&directory=/var/www/hammondb3organ.net/schematics/hammond/organs/m100
All new tubes. Did a power supply filter cap change.
The PT gets hot quickly. Too hot to touch. The B+ is a bit low.  All this before and after the cap job.
I measureed the AC curent at 1.8 amps.
What could be wrong?
Call me Dan
www.fydamps.com
Offline FYL
Re: Hammond M100 Ao29 on the bench
« Reply #1 on: July 05, 2010, 05:07:21 pm »
Shorted turns in the PT maybe. Does the PT still get hot with an unloaded secondary?
Offline LooseChange
« Reply #2 on: July 06, 2010, 05:01:51 am »
Yes... Unloaded still hot.  Got to find a replacement.
It's been a transformer market at the shop lately.
Call me Dan
www.fydamps.com
Offline LooseChange
« Reply #3 on: July 06, 2010, 05:17:58 am »
Okay... recommndations for the PT??
320-0-320 on the HV
5v-3A filament
6.3v with center tap (what amperage?)
Call me Dan
www.fydamps.com
Offline Dave
« Reply #4 on: July 06, 2010, 07:11:29 am »
Look on Fleabay. They are there all the time. M-100 series, M-3, and L-100 series will all fit and work fine.
Possible exception.... some early M3's had a physically larger PT but it was grey in color so if you see an M3 PT that is black you'll be good to go.
Dave
Offline FYL
« Reply #5 on: July 06, 2010, 09:12:20 am »
According to my docs the AO29 is supposed to use a H-AO-22111-1 power transformer spec'ed at 355-0-355V unloaded and 320-0-320V @ 150mA, 5V @ 3A, 6.3V @ 4A. But I'm no Hammond expert and can't vouch for this info.
Finding a spare is quite easy: there are many cannibalized amps and spares floating around.
