September 19, 2026, 06:42:52 am
Hoffman Amps Forum image Author Topic: Hacker amp  (Read 8010 times)
Offline Leevi
    • Rikstone
Hacker amp
« on: July 24, 2010, 03:44:17 pm »
I own an old British Hacker amp. It has been manufactured by a British company called Hacker Radio LTD. Since there have been made several modifications during the years I would like to find the original schematic for the amp. The tubes are 2 x ECL86 and 1 x EZ81. If there are not schematic available I could change the circuit by using the existing tubes so I'm very interested to find a schematic using 2 x ECL86. If you know any please reply.
/Leevi
Offline VMS
Re: Hacker amp
« Reply #1 on: July 24, 2010, 04:28:41 pm »
Hi Leevi, is your google broken  :grin:
Here is a schematic to one Hacker amp with 2 x ECL86 and 1 x EZ80:
http://sites.google.com/site/projectdevoid/file-cabinet
I also found couple of interesting Mullard circuits that use ECL86 tubes:
http://www.r-type.org/static/2-3.htm
http://www.r-type.org/static/4-10.htm
Offline harryk
Re: Hacker amp
« Reply #2 on: July 24, 2010, 04:30:25 pm »
Hi Leevi! I have built one amp with a pair of ECL86 tubes. It is Bluetone Express Baby with Trainwreck Express preamp with my own power amp design. If I remember right, its schematics can be found in my web pages www.bluetone.fi and there Bluetone Express Baby. I like the sound of that tube very much, but they start to be pretty expensive. That is why I do not use them in other projects. Anyhow I still have a couple of them (NOS) if you need. Harry
Offline Leevi
    • Rikstone
Re: Hacker amp
« Reply #3 on: July 24, 2010, 05:29:04 pm »
Thanks for the replies guys!
VMS: My Google is working well and now even better when I downloaded the Google's own browser named Chrome. Maybe I should be more patient when searching things. The schematic under the link you send is pretty close to circuit of my amp. The Mullard circuits are interesting too.
Harry: I found the circuit from your great pages but it seems to be meant for a power amp only. My idea was to build both the preamp and power amp by using two ECL86s.
Leevi
Re: Hacker amp
« Reply #4 on: July 24, 2010, 06:53:17 pm »
Doubtful.
You have two power pentodes. Each needs about 10V peak or 7V RMS drive. You probably want to work push-pull. You should use a push-pull driver. With two triodes the best you can do is a high-gain volt-amp follewed by a cathodyne. Gain to each grid will be 70 at best. The input sensitivity is about 7V/70 or 0.1V or 100mV RMS. Guitar amps typically have input sensitivity of 50mV to 5mV. You need another gain of 2 to 20.
Maybe the most direct "cheat" is to use a small MOSFET as the cathodyne. Then you have two triodes' worth of gain which is more than ample.
Alternatively you could sneak a JFET in as the first stage. Well-done it has less hiss and hum than a typical tube. And the distortion can be "similar" to a tube.
The only push-pull commercial amp with just two triodes as pream/driver is the small Fender bass amp. It used an interstage transformer to get phase split. It has some collector appeal, mostly I think because it was so mediocre that it didn't sell well when new and is now slightly scarce. The interstage transformer was custom and not easily emulated. And transformer-driven guitar amps have rarely been as popular as cap-coupled drivers.
Offline Leevi
    • Rikstone
Re: Hacker amp
« Reply #5 on: July 25, 2010, 12:56:10 am »
Yes, it's challenging to get it working as a p/p amp. I thought another idea:
I could use the rectifier socket for a 12AX7 and replace the EZ81 with an SS rectifier.
Then I have more choices for the preamp and I could use the circuit Harryk presented
in his reply.
Leevi
