September 14, 2026, 06:15:56 pm
Hoffman Amps Forum image Author Topic: Reverse diodes plate to ground - really need them??  (Read 7832 times)
Offline LooseChange
    • Fix Your Darn Amps
« on: August 11, 2010, 06:42:06 am »
Just curious... Are those "protection" diodes that go from power tube plate to ground really needed? Or are they an overkill UL/CSA requirement?  I've had more than one amp with these gone bad. I replace them but would the OT had blown if these diodes were not there?
Most modern amps have a HT fuse too, isn't that enough??
Thanks!!
Call me Dan
www.fydamps.com
Offline FYL
Re: Reverse diodes plate to ground - really need them??
« Reply #1 on: August 11, 2010, 11:31:11 am »
The jury is still out on this.
Offline Merlin
« Reply #2 on: August 11, 2010, 04:14:36 pm »
This was discussed recently at MEF:
http://music-electronics-forum.com/t20957/
They aren't strictly necessary. Lots of people do without them, especially if there's a permanent resistor hooked up to the secondary to protect against a disconnected speaker.
Offline Bierschinken
  • Crank it up!
« Reply #3 on: August 15, 2010, 10:48:35 pm »
Hello,
a thing that is often ignored; the peak which damages the OT while running without a load endures only a nick of a second and standard diodes are too slow to open up and let them pass to ground.
Therefore you have to use realy fast diodes such as booster diodes used in old tube-monitors.
- Swen
Offline Merlin
« Reply #4 on: August 16, 2010, 03:22:03 am »
Ordinary diodes are fast enough to clamp the voltage across a relay coil, so I would expect the same to apply in this application?
  • Crank it up!
« Reply #5 on: August 20, 2010, 08:21:14 pm »
Honestly I´m not familiar enough with those things but to my extend the relay coil differs from the OT in the way they work.
If you turn off the voltage from the relay, the coil starts a process of selfinductance to maintain the currentflow. So the reverse-voltage raises "slow" but steady to the point where the diode breaks through and shunts to ground. So a standard diode is sufficient.
On a OT it appears that there is not such a steady process of selfinductance but a very fast impulse-like inductance with pretty strong peaks.
And it´s those peaks which only last hundredth of a second or so which are too fast for standard and "UF"-Type Diodes.
As I´ve sai, I´m not an expert on this, but this is how I think it does work  :smiley:
- Swen
Offline LooseChange
« Reply #6 on: August 21, 2010, 05:58:20 am »
I asked this question over at the Powerscaling.com board and they came up with a "no" on the diodes but instead adding a "tethering" resistor 330k in it's place.
Call me Dan
www.fydamps.com
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #7 on: August 22, 2010, 09:35:04 am »
I haven't seen those diodes do anything except short out and blow the fuse. Most amps don't have them.
« Reply #8 on: August 22, 2010, 09:44:13 am »
Now there's a term I've never heard.
Offline LooseChange
« Reply #9 on: August 22, 2010, 10:56:27 am »
KOC terminolgy.  :grin:
Call me Dan
www.fydamps.com
