September 24, 2026, 11:59:39 am
Hoffman Amps Forum image Author Topic: Tube and Voltage change on the TOS amp  (Read 7299 times)
Offline 67polara
  • Here is my Guild 67 polara
« on: August 29, 2010, 09:14:11 pm »
Hello all.  I was thinking that when I build the T.O. special that I would use KT77 and up the voltage to 475v into a 4.2 k load.  What power out put might I expect and would it have any adverse effects on the existing circuit and or sound quality?
Tony
« Last Edit: August 29, 2010, 11:59:25 pm by 67polara »
Offline stingray_65
Re: Tube and Voltage change on the TOS amp
« Reply #1 on: September 03, 2010, 11:03:01 pm »
Hey Tony,
I don't know how I missed this post.
Check out the data sheet here. http://www.tubezone.net/pdf/kt77mov.pdf
It's interesting to see the note near the bottom of pg4 that mentions mounting distance of 3 1/2" minimum, I am unsure why.
I am not seeing anything in class AB1 fixed bias, but from looking at other charts we can guess between 60 and 70 watts.
The 4.2k impedance is a close enough match to the declare optimal 5.0k for P-P operation.
I would also consider tying pins 1 and 8 on your sockets so that other tubes might be installed
I could not imagine what tonal effects running KT77's would have. My only experience with these were in HI-FI equipment and even then they were ran ultra linear. (very loud VERY clean)
Ray
Offline 67polara
« Reply #2 on: September 04, 2010, 01:13:46 am »
Thanks Ray.
I just noticed I can't find the exact spec's for my power transformer, that is current capabilities.  The part number is 029032 a fender part.  It is a bastard I guess.
This is what I know:
355v no center tap
6.3 volt no center tap
54 volt bias windings
No 5 volt windings
I need to know the power handling capabilities and the 6.3 volt current available.  I need a little more than 4 amps 4.1 to be exact for the 6.3 windings. It came out of a fender super 60 red knob that had 2 x 5881's in it so I believe it is out of a 50 watt.  The KT77 require 1.4 amps each instead of .9 for 6l6's.  I think I will stay with cathode bias at first and see how that works out.  I don't want to stress the output tranny to much, but I want lots of clean headroom.
Can anyone help me please?
Tony
« Last Edit: September 04, 2010, 01:26:03 am by 67polara »
Offline Geezer
Offline 67polara
« Reply #4 on: September 05, 2010, 11:17:54 pm »
Thanks Geezer, but I already have that information what I need is the max filament current available for that transformer.  Can't seem to locate that information.
Tony
Offline Geezer
« Reply #5 on: September 06, 2010, 07:14:18 am »
That info is probably lost to the sands of time.........
The Super 60 required ~~3A filament current
The TOS w/ KT77's will need ~~4A
If you're concerned about the PT's safety, you could run the big tubes off the PT filament supply, & get a small 6.3V tranny to run the little tubes.....they are very inexpensive. I think I paid ~~ $7 for one.....yep, here's the link to a 3A unit (Doug also sells them)
http://www.mouser.com/ProductDetail/Xicon/41FD030/?qs=sGAEpiMZZMv4oUrzpPKU3NKK6KmzX%252bbMxt1WBAv2nNQ%3d
Offline 67polara
« Reply #6 on: September 06, 2010, 11:44:22 am »
Great idea I never thought of that!!!  That will fix everything  :grin:
Thank you Thank you
Tony
Offline 67polara
« Reply #7 on: September 12, 2010, 11:40:54 pm »
Can you point me to a place to buy the filament transformer please.  Seems like all I see they are really proud of and maybe I should just buy a new power transformer for a few bucks more.  I have a small power transformer also maybe I will just use that one this amp is gonna weight a ton anyways so what could a couple pounds more hurt LOL.
If I have the current I will probably add reverb and trem to it LOL the chassis is the size of a small car anyways LOL it's from a Smarvo 300 watt bass amp.  It had 6 KT88's on it but the iron was missing when I picked it up.  I got the chassis and case for free though.
Tony
Never mind I didn't see the link you put on there for the tranny my bad.
« Last Edit: September 13, 2010, 12:01:39 am by 67polara »
