September 17, 2026, 02:03:45 pm
Hoffman Amps Forum image Author Topic: tube cooling  (Read 10003 times)
Offline 67polara
  • Here is my Guild 67 polara
tube cooling
« on: September 01, 2010, 09:24:19 am »
If I use a small fan to pull air across my tubes how close can I put them together (3 tubes 9 pin)?  I know what it says in the data sheet and I don't have that much room.  I believe that is for natural convection cooling.  Oh that brings up another question if you take a tube and stick it in another metal tube how the heck does it keep from burning up?
Tony
Offline 67polara
Re: tube cooling
« Reply #1 on: September 04, 2010, 10:00:21 pm »
I am contemplating building a tube operated overdrive pedal.  It will be built in an old Akai tube Shred-O-Matic foot pedal.  That thing was never any good so it was a pleasure tearing it apart.  LOL  It sounded more like fingernails on a chalk board instead of distortion. I think the tube in it only had 1/2 of the filament lit so you thought it was a tube but really it was diode clipping.
Tony
« Last Edit: September 05, 2010, 12:21:01 am by 67polara »
Offline Cups
Re: tube cooling
« Reply #2 on: September 15, 2010, 07:49:27 pm »
I think once you get to three tubes you need to either go half outside the box (electro harmonix) or go 1U rackspace. What desing would possibly need 6 triode stages?
Offline Cups
Re: tube cooling
« Reply #3 on: September 15, 2010, 07:50:49 pm »
That last sentence sounds confrontational where it should just express curiosity. :angry: :wink:
Offline 67polara
Re: tube cooling
« Reply #4 on: September 17, 2010, 10:25:37 am »
No problem, it is actually the preamp section of the TOS with 1 triode as a buffer for the output.
So it is 4 triode stages and one pentode.
Tony
Offline 67polara
Re: tube cooling
« Reply #5 on: September 17, 2010, 11:05:01 am »
The more I try to make this work the more I realize you are right it just "ain't gonna fit"  Different enclosure with foot switch is the way I'm leaning now.
Tony
