Marwi switch housing for bike handlebars
| Click on the images for a larger image | |
The two piece Marwi switch housing snaps together. There are guide pins on the lower half that insert into holes on the upper half. The back side of the housing is curved so it fits on a round surface, like a Bike handlebar The big hole that the switch goes through is 11.2mm in diameter The Velcro strap is approximately 6 inches long There is a slot in the body that the Velcro strap runs through. The Marwi switch housing and the switches that fit this housing can be found on my switches page here. |
Here you can see a close up of the two half's of each switch housing The internal section where the switch body fits is 14mm wide x 20mm tall |
The switch housing assembled with a short switch and a short switch boot The switch and the switch boot do not come with the switch housing I stock those items on my switches page. See the links on this page |
A close up shot of the switch assembly strapped down to a piece of 1 inch diameter tubing. The rubber switch boot seals everything nicely |
This is how the switch housings look with a tall switch and tall switch boot and a short switch and short switch boot |
This image shows the two types of switch bodies that fit the Marwi housing One switch is taller than the other. Each switch also has it's own switch boot, a tall boot and a short boot. I stock several types of switches that fit this housing SPST tall, short and several NC and NO momentary sitches The Marwi switch housing and the switches that fit this housing can be found on my switches page here. |
Here's a shot of the switch housing mounted on one of my bikes the round wire you see in the picture is mini shielded cale I stock this cable on my wire and cable page |
Here's a shot of the switch housing mounted on one of my bikes |
This is my double Marwi XML rig with two Marwi thumb switches I can turn on each light individually with it's own thumb switch |
