Using Judco Flat style switches with the Bullet shaped Marwi Housings |
The rear plastic section on a Marwi Bullet shaped housing Note that only these Judco flat style switches fit into the Marwi Bullet shaped housings To install the switch, first you slide the metal pin over out of the way. The Judco Flat switches slide right into the housings. Then slide the metal pin back over and you are done. The metal pin locks the switch in place. The soft rubber cap on the housing contacts the switch plunger when pressed. I have several styles of these flat switches available on my web store. Normally Open, Normally closed momentary and SPST On/Off latching . |
