September 15, 2026, 12:17:27 am
Hoffman Amps Forum image Author Topic: 5879 octal equivalent?  (Read 12463 times)
Offline Quatro
« on: March 09, 2013, 05:31:11 pm »
Anyone out there know off the top of their head if there is an 8 pin tube or tubes that are equivalent or close in specs to the 5879?
thx
Offline Backwoods Joe
Re: 5879 octal equivalent?
« Reply #1 on: March 09, 2013, 07:24:52 pm »
The 6SJ7 is a Sharp-cutoff pentode but it has higher transconductance, plate disipation and heater current requirements. That seems to be the case when comparing the octals to the newer 9 pin tubes. The 6SJ7GT is the same tube in a glass envelope.
« Reply #2 on: March 09, 2013, 09:46:00 pm »
6J7 is closer electrically to 5879 than 6SJ7.
6SJ7 and EF86 are close electrically.
6SH7 and 6AU6 are electrically same.
6J7/6SJ7/6SH7 are all octal except 6J7 has grid cap. i like 6J7, followed close by 6SJ7.
Offline Quatro
« Reply #3 on: March 09, 2013, 11:49:30 pm »
thx gents.
« Reply #4 on: March 10, 2013, 10:19:36 am »
When comparing triodes, the figure of merit is mu. That's the key parameter you look at to see how one triode will behave when compared to another.
For pentodes, the figure of merit is transconductance (Gm). For pentodes, gain is pretty much Gm time load resistance.
So look for another pentode with a Gm similar to the 5879... at the same plate current. Cause Gm changes with plate current.
Offline smackoj
« Reply #5 on: March 10, 2013, 02:43:05 pm »
<tubes are all octal except the 6J7 has 'grid cap'>  D-load
does that mean the tube has the small metal cap on top that the wire from the chassis attaches too?  are those always a 'grid' line going to the cap?
muhas gracias amigos.
 :icon_biggrin:
« Reply #6 on: March 10, 2013, 03:29:50 pm »
 :icon_biggrin:
Si. In this case it is. Sometimes the cap is plate but mostly on power tubes. On preamp tubes it's a grid. Some older preamp tub es have a grid in base and a grid cap.
« Reply #7 on: March 11, 2013, 06:16:37 pm »
DummyLoad, I've tried to find the cap that fits the 6J7 and all that i can find are made in China. Do you have a lead on some USA made caps. Also have you ever had issues with the caps coming off or getting loose?
« Reply #8 on: March 11, 2013, 10:48:06 pm »
the pair i have i got at a ham swap meet. leeds radio 4 for a 7 bux.
http://leedsradio.com/parts-sockets.html
