September 14, 2026, 07:28:13 am
Hoffman Amps Forum image Author Topic: 7 Cylinder amp for the new chassis - Is this layout "politically" correct ?  (Read 12306 times)
I'm not asking to revise the layout, but I would like to know if it seems correct as general distribution of the path
this is the schematic
Here the original project with photos
http://www.bensykora.com/7cylinder.html
and this is the layout I've draw
« Last Edit: November 28, 2014, 05:19:55 pm by kagliostro »
Volume pot is very close to output transformer and power tube plates.
"7 cylinder" caught my eye. For an instant I said "there are no 7 cylinder engines", then DUH!! I remember all those Radial engines.
http://en.wikipedia.org/wiki/Fiat_A.54
http://en.wikipedia.org/wiki/Fiat_A.50
http://en.wikipedia.org/wiki/Jacobs_R-755
I had no idea that Isotta Fraschini was still in business. Used to be exotic race cars and stuff. Now a lot of very large Diesel engines, to 67 Liters. Anyway they once made a very large 7-jug radial, but I can not find a picture.
« Last Edit: November 28, 2014, 09:03:14 pm by PRR »
Ciao PRR
The layout for tubes and transformers will be the same as in Doug's Stout
A pair of month ago I met a guy who lives not far from my town, he is member of a CNC forum where also I'm member, he is an HiFi passionate
and in the past has had its own HiFi brand and a model of guitar amp in production
he also had a brand who builded this kind of stuff, the activity had problems (here in Italy at the moment isn't impossible to be without) and stopped the production
but now he is newly starting the activity
give a look here
http://www.slengines.com/constellation_en.html
at his house I've seen other very nice stellar motors
Those small stellar engines are really cool
Thanks for the answer
« Last Edit: November 29, 2014, 01:27:15 am by kagliostro »
It would be a good idea to draw your layout using part symbols which are to-scale, or where the relative sizes are accurate. That will give you a better idea of how long wire runs will be and if wires will cross sensitive areas.
Also, a 100nF cap if very likely not the same size as a 1/2w resistor. You may find your turret board may not want exactly equal spacing, depending on which specific parts you use.
Microsoft Visio is probably too expensive to buy for one-off projects, but I used it to produce the layout of my last amp because every part can be drawn to scale. I knew exactly how everything would fit in advance, and where every wire would run. The amp went together with no surprises (which was a nice change  :icon_biggrin:).
Ahem .... err .... I've Visio, not the latest version, but I've , only I'm not very confident with it, I know, I must study more  ..... :embarrassed:
I've redraw the layout trying to respect a scale
the measures of the top of the chassis are 300mm x 180mm, front and rear panel are 300mm x 60mm
Turet spacing is based on a grid of 10mm, so components are placed on parallel columns that are 10mm distant each other
there are 22 colums (virtually 23) of components in a grid of (virtually) 9 rows distant 10mm each other
As I'm not able to do better, PT and OT as they are on the top of the chassis are draw on one other parallel place as they will be on the
top of other components, they are exactly placed in relation to the other components
Is the ground scheme I've draw correct in relation to Doug's grounding recommendations ?
« Last Edit: November 30, 2014, 11:02:18 am by kagliostro »
Offline printer2
Looking at the schematic I am wondering about the phase inverter, are the 330k resistors right?
I hope .... the PI isn't the usual PI it is a Floating Paraphase, if I'm not wrong
http://www.valvewizard.co.uk/floatingparaphase.html
« Last Edit: November 30, 2014, 11:40:02 am by kagliostro »
missing feedback resistor - 33K
Ciao Pete
Err... which 33k resistor  :w2: :w2:
I don't see one on the schematic, where is it connected ?  :dontknow:
« Last Edit: December 13, 2014, 01:44:01 pm by kagliostro »
Look closely at merlin's schematic. Follow the 1m and 33k. Your amp has 2x330k instead of 2x1m and 33k.
Re: 7 Cylinder amp for the new chassis - Is this layout "politically" correct ?
« Reply #10 on: December 01, 2014, 04:54:56 am »
I see ....
Might be that worths to give a try to that feedback resistor
The autor say the PI is inspired to '60 Supro and Valco design, but I wasn't able to find an exact copy of his solution among those schematics
« Reply #11 on: December 01, 2014, 11:34:38 am »
> Visio,... I'm not very confident with it
I like graph paper. On 1/10th-inch grid a resistor is (maybe) 2 by 6 squares, a 0.47u 600V is (maybe) 5 by 12 squares, etc. I think I can mark-up a grid faster than I can select and drop parts on a computer.
Graph paper is getting harder to find, true. I have two sources for basic 0.1" grid within 15 miles, but if not (or if you need something special), there are on-line graph paper tools which output a PDF you can print when needed.
___________________
_I_ think PT CT should go DIRECT to first filter cap "_", -then- on to common ground.
« Reply #12 on: December 01, 2014, 03:52:56 pm »
PRR
I'll try to get info about graph paper
EDIT: Oh, I see, I've understand what you mean, here we call it Carta Millimetrata, and in the past (years ago) I used it often  :smiley:
« Last Edit: December 01, 2014, 03:58:57 pm by kagliostro »
« Reply #13 on: December 02, 2014, 01:11:15 pm »
Thanks for the suggestion
but, as told, I've Visio and it will be better I study more his usage
At the moment I've draw a new layout that is in scale with the chassis dimensions (assuming a chassis of 300mm x 180mm x 60mm)
« Reply #14 on: December 11, 2014, 05:17:10 pm »
Whell, I followed the council about to use a program that can give real size correspondence and the board become larger of ~4cm
this id my first Visio layout and if you have councils I'm here to listen for it
Here the .vsd Visio file
http://www.mediafire.com/download/16kev1wb7o096u3/7_Cylinder_Layout_Assiali.rar
p.s.: Thanks to Pete & Steve for the 7 pin socket for Visio as I was missing it
« Last Edit: December 11, 2014, 05:37:52 pm by kagliostro »
« Reply #15 on: December 11, 2014, 06:56:39 pm »
That looks much, much better than my first layout.  :thumbsup:
« Reply #16 on: December 12, 2014, 02:00:59 am »
Thanks Steve, isn't me, it's Visio
I was wondering if PI ground is to be connected with the preamp ground or with PA ground ?  :rolleyes:
« Reply #17 on: December 12, 2014, 06:45:36 am »
The 220K grid resistors need to connect to the power amp ground. Since you already have those resistors connected to the negative end of the PI filter cap, just connect the PI cathode R/C to that same turret and put a jumper over to the onboard power amp ground buss. See pic...
« Reply #18 on: December 12, 2014, 07:22:45 am »
Molte Grazie Steve
« Last Edit: December 12, 2014, 07:36:20 am by kagliostro »
« Reply #19 on: December 12, 2014, 01:46:44 pm »
very nice work franco.
« Reply #20 on: December 12, 2014, 02:54:56 pm »
Thanks Pete
but I have no merit, is visio that does everything
« Reply #21 on: December 12, 2014, 03:42:29 pm »
Thanks Pete
Ha! All those nice shapes were made by smart people just like you.  :grin:
« Reply #22 on: December 12, 2014, 03:51:29 pm »
You are right Steve, without those shapes .... Visio is really nothing
Many Many thanks to all the friends that has contributed to the creation of that indispensable database
Offline rafe
  • I have tube amps
« Reply #23 on: November 09, 2022, 11:24:23 am »
File:Inline 7 Cylinder with firing order 1-3-5-7-2-4-6.gifthanks
Rafe
« Reply #24 on: November 09, 2022, 05:30:45 pm »
Of course 7 cylinder radials are very common.
"By 1933, Jacobs had developed its most famous engine, the L-4 seven-cylinder air-cooled radial, with a power rating of 225 hp (168 kW) displacement of 757.7 cu in (12,416 cc). It was better known as by its military designation, R-755.
Due to the tendency of the L-4 engine to vibrate heavily at low rpm, it was given the nicknames Shakin' Jake and Shakey Jake."
In-line Sevens:
2 minute video of 7 cylinders
more
Offline bmccowan
  • Better builder than player
« Reply #25 on: November 09, 2022, 06:06:44 pm »
I ride a Moto Guzzi V7. Not 7 cylinders - a V-twin. But the design of the original Guzzi V-twin was based on a radial aircraft engine. Viva Italia!
Mac
John Prine
Offline thetragichero
« Reply #26 on: November 09, 2022, 09:00:11 pm »
maybe a small nit to pick but the power earth ground should be attached to its own bolt on the chassis instead of sharing a bolt with other grounds (this illustration could just be showing star grounding or whatever but i figure it's best to wire an amp as safely as possible
