September 08, 2026, 08:47:44 am
Hoffman Amps Forum image Author Topic: Wire Voltage Rating  (Read 4548 times)
Offline ncusack
Wire Voltage Rating
« on: May 13, 2015, 02:38:12 pm »
Hello,
I'm wondering if someone here can tell me about the voltage rating printed on wire insulation. If a wire is labeled for 300V is that for both AC and DC voltages? Im curious if 300V wire could be used to extend a PT secondary wire or if 600V should be used? the transformer is 300-0-300VAC.
Re: Wire Voltage Rating
« Reply #1 on: May 13, 2015, 03:14:07 pm »
I believe that rating might be insulation breakdown value, I'm thinking the "normal" wire most build with is stranded 20-22ga, cloth or pvc coated.  you can search the forum, there should be quite a trove of info on "wire size", "wire rating" etc.
« Reply #2 on: May 13, 2015, 09:39:00 pm »
Didn't we talk about this last month?
http://el34world.com/Forum/index.php?topic=18618.0
