September 14, 2026, 03:39:12 am
Hoffman Amps Forum image Author Topic: board drilling template (was: Hi everyone)  (Read 9920 times)
Offline eternalpurple
« on: November 08, 2017, 11:13:37 pm »
I am new to this and was wondering where I might be able to buy a metal board drilling template like or similar to the one Hoffman Amps sold in the past. It seems that would really keep things lined up and the holes going straight up and down through the board instead of at an angle. I  have a drill press to use as well but anything that could help get the job get done faster and cleaner would be a welcome addition. Any help in finding one would be appreciated.
PS.....Great board
{edit-- on-topic title -- PRR}
« Last Edit: November 10, 2017, 10:34:13 am by PRR »
Offline davidwpack
    • My music on reverbnation
Re: Hi everyone
« Reply #1 on: November 08, 2017, 11:21:38 pm »
Re: Hi everyone
« Reply #2 on: November 08, 2017, 11:51:19 pm »
Here's one. https://tubeamplifierparts.com/circuit-board-supplies/drill-templates.html
Thank you very much David. That's a big help.  I'm sure as I go i'll have plenty of questions about builds and buys. I will definitely make this a prominent stop
Offline davidwpack
Re: Hi everyone
« Reply #3 on: November 09, 2017, 12:12:09 am »
You're welcome and welcome to the forum! Hoffman is where I get most of my amp parts and most of my questions answered.
Re: Hi everyone
« Reply #4 on: November 09, 2017, 05:01:31 am »
To the best of my knowledge, there is only ONE link that Doug prefers to not be posted and it is the one mentioned in this thread.  IF my memory serves me correctly, this individual took some ideas that Doug had in building Hoffman style turret boards and never honored or communicated with Doug about this even though Doug reached out to him for communication.
Re: Hi everyone
« Reply #5 on: November 09, 2017, 07:20:57 am »
Yep, that guy is still on my shit list
But I don't make a drilling template so have at it
Offline davidwpack
Re: Hi everyone
« Reply #6 on: November 09, 2017, 10:23:33 am »
Ohhh. I really had no idea about that. Sorry. I did suggest this is the best place for parts and info though.
Re: Hi everyone
« Reply #7 on: November 09, 2017, 10:29:58 am »
It's ok, I don't have what you need, so get it from him :)
Re: Hi everyone
« Reply #8 on: November 09, 2017, 12:23:20 pm »
It may take you a while to receive it from Ken
Re: Hi everyone
« Reply #9 on: November 09, 2017, 04:00:04 pm »
Didn't Hoffman move into the 21st century? A virtual template? You click your dots, his robot does the holes, and it ships back fast.
http://el34world.com/Forum/index.php?topic=22070
http://hoffmanamps.com/php/TurretBoard/CustomBoard.php
Yes, there's situations where having a holy metal slab is better. But for a few amps a year, Hoffman is set-up, whereas I would have to clear the Xmas junk off the drillpress, find a drill bit....
Re: Hi everyone
« Reply #10 on: November 10, 2017, 12:00:33 am »
shame! that's what cellars and attics are for. :p
did you ever get around to restoring that heathkit audio gen?  :icon_biggrin:
Re: Hi everyone
« Reply #11 on: November 10, 2017, 07:31:35 am »
PRR is correct
My on line program is simple and easy to use
Offline bnwitt
  • Crankin' out the tone.
Re: board drilling template (was: Hi everyone)
« Reply #12 on: November 12, 2017, 09:54:11 am »
Doug's CNC drilled boards are cheap and perfect.  You'll never get one as accurate using the old tech drilling guide.  That's why Doug doesn't sell them any more.
Barry
« Reply #13 on: November 12, 2017, 10:06:55 am »
I stopped having the templates made a long time ago
Right after I built my CNC machine I realized I did not need to use a template any more
Plus they cost about $50 each to have made and that was with a qty of 50
Using my on line design program is easy and it submits your design to me
Then my CNC machine makes it for you
The program looks like this
« Reply #14 on: November 16, 2017, 01:13:55 am »
Well I looked on the Hoffman board and It said the idem was discontinued. Which is why I came here to ask where I could find one. When I need other parts I will certainly give Doug first crack. With that in mind what is everyone using larger holes in chassis. something the size of a 6L6 tube socket on down? Thanks
« Reply #15 on: November 16, 2017, 05:24:54 am »
These two step bits do most of my big holes. Greenlee is pricey but they hold up very well. Harbor Freight has a very cheap set that may do a few chassis before getting dull.
« Reply #16 on: November 16, 2017, 10:13:11 am »
My on line custom board program has been re-vamped
It now uses svg graphics and it works on all browsers and mobile devices that I have tested it on
Check out the examples of customer created boards I posted here
See reply #8
http://el34world.com/Forum/index.php?topic=22070.msg242003#msg242003
« Last Edit: November 16, 2017, 10:24:12 am by EL34 »
« Reply #17 on: November 16, 2017, 09:06:59 pm »
[/quote
It's amazing you would be the one that would answer this because it was your revibe unit page I was looking at that brought the question to mind. Thanks for the info.
