Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Trall on October 08, 2012, 11:22:29 am
Hello I have Jolida SJ 302a and i love this amp but its to week for my Usher be-718.
So i was wondering if anyone has any idea how to change it to pre-amp.
it has no RCA outputs , guys at Jolida told me that it is possible but did not say anything more.
Show us the schematic and I will show you where you can connect some RCA ouput jack.
This is the schematic ;
www.drtube.com/schematics/jolida/sj-502a.gif (http://www.drtube.com/schematics/jolida/sj-502a.gif)
I'll connect a RCA jack at resistor R2 ( 1K) Kathode side of the tube, disconnecting this wire to V2A . I'll add a 0.22 capacitor before the RCA jack to insulate from voltage.
Use shielded wire, grounded at one end only.
Do the same for other channel.
If you could guide me with some paint job on that schematic i would be eternally grateful.
> Jolida SJ 302a and i love this amp but its too weak for my Usher be-718.
That's a 60 Watt amplifier. The speakers review well with a 60W amplifier. And 7" woofers shouldn't need (can't handle) a lot more than 60 Watts.
It shouldn't be "to week". Something is wrong.
I never use paint , I don't know how . I have to learn.
Other explanation ; disconnect the wire from R2, the wire going to R4 and V 2a
In place from R2 you connect a shieded wire to your RCA jack with 0.22 cap in serie
In other word ;
The wire from R2 don't go to R4 and V2a , It go to you RCA jack. Is it ok ?
Great thank you very much. Usher is very power hungry.
The Usher Be-718 loudspeaker is specified as Sensitivity: 87dB/W/m.
It's not "power-hungry" but in-sensitive. You may be used to getting more volume from your Jolida amp with other, more sensitive speakers.
