September 17, 2026, 11:31:26 am
Hoffman Amps Forum image Author Topic: Help with jolida mod  (Read 6709 times)
Offline Trall
« on: October 08, 2012, 11:22:29 am »
Hello I have Jolida SJ 302a and i love this amp but its to week for my Usher be-718.
So i was wondering if anyone has any idea how to change it to pre-amp.
it has no RCA outputs , guys at Jolida told me that it is possible but did not say anything more.
stratele52
  • Guest
Re: Help with jolida mod
« Reply #1 on: October 08, 2012, 02:12:26 pm »
Show us the schematic and I will show you where you can connect some RCA ouput jack.
stratele52
  • Guest
« Reply #2 on: October 08, 2012, 02:37:16 pm »
This is the schematic ;
www.drtube.com/schematics/jolida/sj-502a.gif
I'll connect a RCA jack at resistor R2 ( 1K) Kathode side of the tube, disconnecting this wire to V2A . I'll add a 0.22 capacitor before the RCA  jack to insulate from voltage.
Use shielded wire, grounded at one end only.
Do the same for other channel.
Offline Trall
« Reply #3 on: October 08, 2012, 07:16:03 pm »
If you could guide me with some paint job on that schematic i would be eternally grateful.
« Reply #4 on: October 08, 2012, 10:52:43 pm »
> Jolida SJ 302a and i love this amp but its too weak for my Usher be-718.
That's a 60 Watt amplifier. The speakers review well with a 60W amplifier. And 7" woofers shouldn't need (can't handle) a lot more than 60 Watts.
It shouldn't be "to week". Something is wrong.
stratele52
  • Guest
« Reply #5 on: October 09, 2012, 04:10:04 am »
I never use paint , I don't know how . I have to learn.
Other explanation ; disconnect the wire from R2, the wire  going to R4 and V 2a
In place from R2 you connect a shieded wire to your RCA jack with  0.22 cap in serie
In other word ;
The wire from R2 don't go to R4 and V2a  , It go to you RCA jack. Is it ok ?
« Last Edit: October 09, 2012, 04:20:49 am by stratele52 »
Offline Trall
« Reply #6 on: October 09, 2012, 09:22:59 am »
Great thank you very much. Usher is very power hungry.
« Reply #7 on: October 09, 2012, 04:09:59 pm »
The Usher Be-718 loudspeaker is specified as Sensitivity: 87dB/W/m.
It's not "power-hungry" but in-sensitive. You may be used to getting more volume from your Jolida amp with other, more sensitive speakers.
