Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Smalls on September 10, 2017, 02:15:33 pm
Title: Wiring 6cm6 tube socket!
Post by: Smalls on September 10, 2017, 02:15:33 pm
    Hello everyone,
I want to soy say ahead of time that I appreciate all input on this problem. Also, my knowledge of tube amps is tiny. I've built one amp. Rob Robinette's "deluxe micro". It is a nice little amp but want a little more output. So, I am putting a 6cm6 power tube in it. The problem that I am having a problem understanding the wiring of the tube socket. Anyways, if someone could help me I would be soooo happy!!!
          Thnx!
Title: Re: Wiring 6cm6 tube socket!
Post by: sluckey on September 10, 2017, 03:22:03 pm
This should help...
http://tdsl.duncanamps.com/show.php?des=6CM6 (http://tdsl.duncanamps.com/show.php?des=6CM6)
Post by: tubenit on September 10, 2017, 03:34:51 pm
DummyLoad  (Pete) and I worked on a push/pull low watt gallery of amp designs yrs ago ...................
Maybe there will be something there that would be useful to you:
http://el34world.com/Forum/index.php?topic=12526.0 (http://el34world.com/Forum/index.php?topic=12526.0)
with respect, Tubenit
Post by: DummyLoad on September 10, 2017, 08:44:11 pm
you are going to need a different output transformer as well. an 8W 100Hz-15KHz 10k ohm reflected sould work. 400V is too much & will not sound worth a damn with that much B+. 300-325V is where you want to be with that tube. 6MC6 is a 6V6GT in 9 pin package.
Post by: Smalls on September 10, 2017, 11:03:25 pm
Thnx for the replies. Would the classic tone 40-18031 a proper output transformer?
Post by: sluckey on September 11, 2017, 06:32:18 am
yes
