Amp Stuff => AmpTools/Tech Tips => Topic started by: chocopower on June 09, 2019, 12:34:15 pm
Title: Cheap "variac". To good to be true?
Post by: chocopower on June 09, 2019, 12:34:15 pm
Hi there?
I found this in ebay. Is safe to use as variac for tube amp work?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.es%2Fulk%2Fitm%2F323583637603 (https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.es%2Fulk%2Fitm%2F323583637603)
Title: Re: Cheap "variac". To good to be true?
Post by: shooter on June 09, 2019, 04:35:30 pm
probably, the specs and my Spanish are sketchy  :laugh:
I'd make sure your "test" amp has a good fuse  :icon_biggrin:
Post by: kagliostro on June 09, 2019, 04:57:23 pm
I think that isn't usable to feed amplifiers
seems to be a voltage regulator not a real Variac
Post by: DummyLoad on June 09, 2019, 06:25:27 pm
agree with franco: seems like a solid state phase control rather than a variable transformer.
i wouldn't use it.
BTW: the word "variac" started out as a general radio trademark for their line of autotransformers (variable transformer) first filed in 1933. general radio is defunct and a holding co., Instrument Service & Equipment, Inc. owns the trademark now.
Post by: chocopower on June 10, 2019, 03:19:34 am
Thanks.  Just what i thought.
I found this analysis (in English)
Post by: sluckey on June 10, 2019, 08:38:41 am
Not my English.  :icon_biggrin:
That is the same link as in your original post.
Post by: vampwizzard on June 10, 2019, 09:11:01 pm
Vary voltage up to 4000W. P = VI.. at 120V youre good up to 30watts of total current draw. (90% efficiency, 33.3 watts at 100% efficiency)
For small amplifiers this may be ok, but I would personally use a dedicated variac.
Post by: DummyLoad on June 10, 2019, 10:14:58 pm
you do mean 30 AMPS, yes? 4KW at 120V would be 33.33A.
Post by: PRR on June 10, 2019, 11:31:20 pm
Just by the size, this can't be a 3000VA autotransformer.
The fit of screws/holes does not promise precision construction.
I think it is a lamp-dimmer. Incandescent lamps, simple heaters, etc. "Some" wall-power motors can be run on a dimmer. (Others burn-up and fill the attic with smoke....)
Post by: chocopower on June 11, 2019, 08:07:10 pm
Sorry....
https://owenduffy.net/blog/?p=11745 (https://owenduffy.net/blog/?p=11745)
Post by: PRR on June 11, 2019, 11:58:55 pm
It is a triac lamp-dimmer. And not done well.
Aside from electrical shock, this will BURN a power transformer.
