Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: pc1093 on March 10, 2020, 01:58:23 am
Title: Mains Transformers 0-6.3V,3.15V-0-3.15V different
Post by: pc1093 on March 10, 2020, 01:58:23 am
hi all,
what's different between 0-6.3V and 3.15V-0-3.15V in the main transformer?
most of heaters connect to  3.15V-0-3.15V, could I use 0-6.3V?
Title: Re: Mains Transformers 0-6.3V,3.15V-0-3.15V different
Post by: d95err on March 10, 2020, 03:15:22 am
You can create a ”virtual” center tap for the 0-6.3V winding by using two 100 ohm resistors, to get a balanced ground reference.
This works fine (some say it’s even better than a real center tap).
Post by: kagliostro on March 10, 2020, 07:31:55 am
You can also go further and use a 220R pot instead of the fixed 100R resistors (connect the wiper of the pot to ground)
this way you'll have the opportunity to rotate the shaft of the pot for the maximum hum rejection
Post by: jjasilli on March 10, 2020, 07:35:30 am
3.15V-0-3.15V: if you don't use the CT, then it's functionally  a 0-6.3V tranny.
Post by: pc1093 on March 10, 2020, 09:14:59 am
I find a Transformer with 250-0-250. My Amp just need  250V(before Smoothing and Filtering) for the HV. Would I only use 250-0 wire for the HV and insulated the other 250 wire?
(http://)
Post by: kagliostro on March 10, 2020, 09:42:59 am
...... Would I only use 250-0 wire for the HV and insulated the other 250 wire?
NO, connect CT to ground and rectify using two diodes
(https://i.imgur.com/NmYdNMC.jpg)
http://www.valvewizard.co.uk/bridge.html (http://www.valvewizard.co.uk/bridge.html)
If you want (and circuit requirement permit) you can use a 6.3v Vacuum Tube Rectifier instead of the pair of diodes, but rectifier must be indirect heated
(https://i.imgur.com/ScvewdB.png)
Tubes like the EZ81 http://www.r-type.org/pdfs/ez81-1.pdf (http://www.r-type.org/pdfs/ez81-1.pdf)
are fine for this use (if the voltage and current spech are within the requirement of the circuit of the amp)
Post by: pc1093 on March 10, 2020, 10:32:24 am
In this connection, is it 500V ?
Post by: shooter on March 10, 2020, 11:32:04 am
follow the link for good read
will answer that question AND why  :icon_biggrin:
(I'll give you a hint, NO:)
Post by: pc1093 on March 10, 2020, 10:29:38 pm
I got the point.
In this connection(http://www.valvewizard.co.uk/bridge1.jpg), I have 500*square root of 2 voltage.
In this connection(http://www.valvewizard.co.uk/fullwave1.jpg), have 250*square root of 2 voltage.
right?
Post by: sluckey on March 11, 2020, 04:30:54 am
right
Post by: kagliostro on March 11, 2020, 08:25:22 am
Right
Assuming the transformer used with the FWB has a CT (not connected to GND) and Is the same transformer used with CT connected to GND and the pair of diodes of the second example, not a generic PT without a CT
