September 18, 2026, 12:33:46 pm
Hoffman Amps Forum image Author Topic: Mains Transformers 0-6.3V,3.15V-0-3.15V different  (Read 6849 times)
Offline pc1093
« on: March 10, 2020, 01:58:23 am »
hi all,
what's different between 0-6.3V and 3.15V-0-3.15V in the main transformer?
most of heaters connect to  3.15V-0-3.15V, could I use 0-6.3V?
Offline d95err
Re: Mains Transformers 0-6.3V,3.15V-0-3.15V different
« Reply #1 on: March 10, 2020, 03:15:22 am »
You can create a ”virtual” center tap for the 0-6.3V winding by using two 100 ohm resistors, to get a balanced ground reference.
This works fine (some say it’s even better than a real center tap).
« Reply #2 on: March 10, 2020, 07:31:55 am »
You can also go further and use a 220R pot instead of the fixed 100R resistors (connect the wiper of the pot to ground)
this way you'll have the opportunity to rotate the shaft of the pot for the maximum hum rejection
« Reply #3 on: March 10, 2020, 07:35:30 am »
3.15V-0-3.15V: if you don't use the CT, then it's functionally  a 0-6.3V tranny.
Offline pc1093
« Reply #4 on: March 10, 2020, 09:14:59 am »
I find a Transformer with 250-0-250. My Amp just need  250V(before Smoothing and Filtering) for the HV. Would I only use 250-0 wire for the HV and insulated the other 250 wire?
« Last Edit: March 10, 2020, 09:31:57 am by pc1093 »
« Reply #5 on: March 10, 2020, 09:42:59 am »
...... Would I only use 250-0 wire for the HV and insulated the other 250 wire?
NO, connect CT to ground and rectify using two diodes
http://www.valvewizard.co.uk/bridge.html
If you want (and circuit requirement permit) you can use a 6.3v Vacuum Tube Rectifier instead of the pair of diodes, but rectifier must be indirect heated
Tubes like the EZ81 http://www.r-type.org/pdfs/ez81-1.pdf
are fine for this use (if the voltage and current spech are within the requirement of the circuit of the amp)
« Last Edit: March 10, 2020, 09:55:19 am by kagliostro »
Offline pc1093
« Reply #6 on: March 10, 2020, 10:32:24 am »
In this connection, is it 500V ?
« Reply #7 on: March 10, 2020, 11:32:04 am »
follow the link for good read
will answer that question AND why  :icon_biggrin:
(I'll give you a hint, NO:)
Offline pc1093
« Reply #8 on: March 10, 2020, 10:29:38 pm »
I got the point.
In this connection, I have 500*square root of 2 voltage.
In this connection, have 250*square root of 2 voltage.
right?
« Reply #9 on: March 11, 2020, 04:30:54 am »
right
« Reply #10 on: March 11, 2020, 08:25:22 am »
Right
Assuming the transformer used with the FWB has a CT (not connected to GND) and Is the same transformer used with CT connected to GND and the pair of diodes of the second example, not a generic PT without a CT
« Last Edit: March 11, 2020, 08:27:40 am by kagliostro »
