Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: bullkelp on January 28, 2025, 12:37:55 pm
Title: 6g6b ...switches?
Post by: bullkelp on January 28, 2025, 12:37:55 pm
Im using a AB165 bassman chassis for a 6g6b bassman build. Ive added a hole for the presence control
Im wondering about uses for the slider switches.
I dont think a bright switch is going to be all that useful given the amps presence control. A half power would be something but im not sure how to approach that.
And for the bass channel, I wondered about switching the 2.2nf snubber cap in and out of circuit?
Title: Re: 6g6b ...switches?
Post by: Latole on January 28, 2025, 02:13:31 pm
Schematic;
Post by: Latole on January 28, 2025, 02:22:44 pm
A triode / pentode switching may do the job or a Master volume
Triode / pentode ;
https://el34world.com/Forum/index.php?topic=28185.0
Post by: bullkelp on January 28, 2025, 02:38:35 pm
I mean I’m happy to leave them as nothing switches but seems like a bit of a missed opportunity
Thanks for the triode pentode info I’ll examine it :)
Post by: AlNewman on January 28, 2025, 03:46:34 pm
A switchable bypass cap can be a good option, like a fat switch, or a switch that enhances certain frequencies.
Post by: bullkelp on January 28, 2025, 04:09:45 pm
Yes I like this idea
Post by: Willabe on January 28, 2025, 04:48:00 pm
You can't put a pentode/triode switch where Fender put the bright slider switch.
Post by: bullkelp on January 28, 2025, 04:56:04 pm
No I wouldnt have thought so
Post by: shooter on January 28, 2025, 05:23:31 pm
before a switch, just hard-wire it triode, play til the fingers bleed, re-wire Pentode, repeat.  most of the guitarists i've used, tell me it's not worth it, now the Audiophiles, they will tell you triode is the way to listen to music properly :icon_biggrin:
Post by: Willabe on January 28, 2025, 05:33:08 pm
Most guitarist's don't like triode output power tubes because of the high end roll off, it's a lot, pretty dark sounding.
Post by: dwinstonwood on January 28, 2025, 05:43:46 pm
A while back I wanted to build a 6G6-B with one input and a channel switch. This isn't exactly what you're posting about, but you could switch between channels.  :dontknow:
It's designed to fit in Hoffman's Blank Aluminum Chassis 17 x 6.5 x 2.5: https://hoffmanamps.com/MyStore/catalog/parts6.htm
Post by: bullkelp on January 28, 2025, 05:49:52 pm
Agree
I have an amp with this feature and I dont use it/like very much.
I was thinking of 3d printing an angry tiki for the grill emblem so maybe ill just make one of the swiches a for an LED that makes his eyes glow different colours :)
Post by: Latole on January 29, 2025, 03:33:27 am
Good to know, I never do this mod or try it .
Post by: bullkelp on January 29, 2025, 04:24:03 pm
So I've opted to wire the bass channel switch as an in circuit/out of circuit switch for the 2.2fF snubber cap.
Still mulling over the other one. ..
Post by: Latole on January 30, 2025, 02:35:19 am
Error
Post by: chocopower on January 30, 2025, 05:09:03 am
NFB loop switch.  easy, and usefull.
Post by: bullkelp on January 30, 2025, 11:31:58 am
Yep after testing the amp last night I think something to ease the gain a little might be good.
Whats the best way to wire this with a fender slider switch?
Post by: chocopower on February 03, 2025, 10:50:53 am
take the wire who come from the speaker tap throw the 56k resistor and wire the switch to cut that pad.
you can put a 1m resistor in the middle to avoid the switch noise.
Post by: Merlin on February 03, 2025, 12:01:13 pm
A tone stack defeat / lift switch, maybe?
