Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: joesatch on March 18, 2025, 02:45:37 pm
i was told from various sources that 1 watt plate resistors are fine. Well these 1 watt metal film i have are tiny! are you folks sure 1 watt metal film is enough? these things are the size of a grain of rice
I just installed some of those, so I sure hope so….,
bust out a breadboard, a 'lil math, test for smoke :icon_biggrin:
i have doubts
Some years back, over at Kevin O'Connor's tube amp forum, guys were having trouble with the small body resistors in the B+ power supply. They couldn't take it and were dying.
They went back to the larger body R's and then no more problems.
I don't trust them, the small sized body R's.
Also check the voltage rating of resistors that you are wanting to use where there are big voltage swings
For plate resistors, I think they're fine. As power or dropping resistors, I'm not so sure. I use them quite a bit and haven't had a failure yet.
gonna use them in V1 and V2 plates. hopefully no issues. if i have trouble sleeping i'll pull em
350V probably not enough fml
350v is okay for a preamp plate or cathode load resistor given the likely range of voltage swing. Wouldn’t use them as single bleeder resistors in the power supply tho.
Well, they look smaller than what I'm used to, but not *THAT* bad
Time will tell on the longevity.....
i was told from various sources that 1 watt plate resistors are fine. Well these 1 watt metal film i have are tiny! are you folks sure 1 watt metal film is enough? ...
The resistor's power-rating is about temperature-rise.
"When this resistor dissipates 1 watt, the body-temperature will not rise more than ____ degrees." And we de-rate the resistor to dissipate less than its rating to keep it cool.
The implication is something about this resistor's construction enables it to throw off heat-to-the-air faster/better than older designs, such that it does not need a big surface-area to lose heat to the air via convection (or as-much surface-area as older designs).
If you want to use a 5w resistor because you like the size & look, you can use a 5w resistor. Or get used to some newer ones being a lot smaller than what you used in the past (and assume you're gonna need a meter to verify their value, because reading the color codes is impossible).
Just as a reference. I have been inside several two rock 100 watt amps and they use the tiny 3mm x 8mm KOA CF resistors on the plates of several preamp tubes.
They hold up fine and they are only 1/2 watt.
Here is the data sheet on them
https://www.mouser.ca/ProductDetail/660-CF1-2C683J
I was surprised when I saw them too!
Cheers
Guy
