September 25, 2026, 09:15:12 pm
Hoffman Amps Forum image Author Topic: 5B2 question  (Read 5602 times)
Offline Madison
  • What's up slobbies?
    • Funky Dolphins
5B2 question
« on: September 10, 2010, 12:18:50 am »
The .01 cap after the input jacks.
1. What is it for?
2. Can it be eliminated and just go with a standard "hi" single input with the 68K and 1M resistors?
Offline FYL
Re: 5B2 question
« Reply #1 on: September 10, 2010, 06:24:20 am »
The 5B2 uses grid leak bias, with a large resistor between grid and ground - 4M7 if I remember correctly. The coupling cap isolates the input from the DC bias current.
You can't just use the standard 68K/1M combination without adding a suitable cathode bias section to V1a. But it won't be a 5B2 anymore...
Offline Madison
    • Funky Dolphins
Re: 5B2 question
« Reply #2 on: September 10, 2010, 07:57:55 am »
No prob.
I am more interested in fiddling with octal.
Can I just wire up the 6SL7 V1 like a 5C2?
I realize the pin outs are different for the V-1s but bus cathodes on a 6SL7?
Just seems simplified.
Offline FYL
Re: 5B2 question
« Reply #3 on: September 10, 2010, 11:26:46 am »
A grid leak stage uses a grounded cathode, hence no cathode resistor + bypass cap.
You may use the usual 1K5 + 22µ cathode and 82K to 220K plate R if you want a standard 6SL7 stage; or keep the 5B2 grid leak stage w/ an input coupling cap, 4M7 grid to ground, 220K to 250K plate - large plate R's are a must in order to limit current - and no cathode R.
Grid leak stages have an interesting sound of their own with a lot of gain, smooth compression and very little dynamic range. They sound best when playing with old-style single coils and no effects.
Offline Madison
    • Funky Dolphins
Re: 5B2 question
« Reply #4 on: September 11, 2010, 01:19:12 am »
Excellent.
Thanks for all the advice!
I'm going to get to work and report later.
