August 29, 2026, 08:52:53 am
Hoffman Amps Forum image Author Topic: ID this tube!  (Read 8855 times)
Offline Trevor_Long
ID this tube!
« on: September 13, 2010, 10:35:10 am »
Hey Guy's,
I'm assuming this is an electron tube of some sort... can anyone here identify?  There are no visible markings.
Thanks!
Re: ID this tube!
« Reply #1 on: September 13, 2010, 03:31:48 pm »
833A
A.K.A. CV0635 833 833A GL833A C833 TY4-350 WL833A T833A ES833 B142
350 Watts plate, 100 Watts filament. Pair with 3,000V-4,000V will get you 1,600-2,600 Watts audio.
http://www.mif.pg.gda.pl/homepages/frank/sheets/049/8/833A.pdf
http://www.mif.pg.gda.pl/homepages/frank/sheets/111/8/833A.pdf
http://www.r-type.org/exhib/aag0032.htm
Worth a couple hundred bucks in as-new condition:
http://www.tubedepot.com/nos-833a.html
You just got the one?
If you could source a 500V 700mA supply and a 700-1K 700mA SE OT, and a 6550 grid buffer, you might be able to build a 130 Watt hellufa-Champ amp slightly heavier than an SVT.
Else: get an old large PC power supply. Jumper the ATX pins to turn it on. Put 8 ohms 20 Watts (Radio Shed part) on the +5V to load it. Find 0.2 ohm 50 Watts of resistance to put in series between the 12V out and the 10V 10A filament. Night-light!
Offline Trevor_Long
Re: ID this tube!
« Reply #2 on: September 13, 2010, 05:45:20 pm »
Thanks PRR!  I had a hunch you would come through with this one!
So, I suppose this was utilized in a radio station or something of that nature?
Re: ID this tube!
« Reply #3 on: September 13, 2010, 08:26:12 pm »
« Last Edit: September 13, 2010, 08:28:56 pm by PRR »
Offline toomanyslurpees
Re: ID this tube!
« Reply #4 on: September 14, 2010, 12:54:51 am »
My vote's for the hellufa-Champ!
Offline billcreller
  • 1934
Re: ID this tube!
« Reply #5 on: September 14, 2010, 01:43:18 am »
  I seem to remember my brother mentioning that particular tube.  He's a ham-radio nut.  I figured it to be a transmitter tube, with the heavy duty posts etc.
Offline supro66
Re: ID this tube!
« Reply #6 on: September 14, 2010, 05:46:52 am »
My Yaesu 401-B has two 6KD6 tubes
I thought these were big  :huh:
 6KD6 finals (2), 33w plate dissipation =
66w total. With 560 W PEP input, 50%
efficency, over 200 watts in heat... big
fan to keep these tubes cool.
http://www.ne.jp/asahi/myamada/tube/TUBE_LIB/6KD6_6JS6_6CB5/6JS6_6KD6.JPG
« Last Edit: September 14, 2010, 06:17:09 am by supro66 »
Offline bmack
Re: ID this tube!
« Reply #7 on: September 14, 2010, 02:02:34 pm »
&feature=related
Just saw this the other day.  Even though it's recorded with a crappy camcorder mic, you can tell it would sounds real nice in the room.
Re: ID this tube!
« Reply #8 on: September 15, 2010, 01:47:48 am »
I've seen the movie
&feature=related
Night-light!
now I understand
a very nice one  :smiley:  :smiley:  :smiley:
Kagliostro
« Last Edit: September 15, 2010, 01:50:21 am by kagliostro »
Re: ID this tube!
« Reply #9 on: September 16, 2010, 09:41:14 am »
thought about building an amp with one of these
use almost common as dirt 6600Ω 50W iron w/ 8Ω load on 4Ω tap. a very manageable 36Vpp to drive to 44W. use separate PS for G2.
hammond 279X w/ SS FW gets you to +600V and change. 379X adds a 50VAC bias tap. hammond 1650H or 1650P for OT.
a friend offered me a pair - i just didn't want to part with the $$$.
