September 08, 2026, 01:57:28 pm
Hoffman Amps Forum image Author Topic: Mic Pads  (Read 8944 times)
Offline Bassmanster
  • Rarrrawweth!
Mic Pads
« on: September 15, 2010, 01:19:27 pm »
Anyone built?  I like my sensitive mic pre for spoken word, but I have to turn it down too much for a screaming amp, especially if I use a condenser.  It gets dull.
There are the XLR inline ones, but it would be nice to make a box with several dB reductions.
I will be swift.  And merciful.
Offline RicharD
    • Toxic Water
Re: Mic Pads
« Reply #1 on: September 15, 2010, 09:10:53 pm »
http://hairballaudio.com/shop/index.php?cPath=27&osCsid=737912ebe94558a04c0306b00ce1b3cd
35 clams
Seems expensive, but you can hardly source parts for a stepped T pad for less.  Plus it would take quite a while to build.  Schematic attached.
Re: Mic Pads
« Reply #2 on: September 15, 2010, 11:21:02 pm »
Those are both 600:600 pads.
Microphone pads should be different.
In fact you can't make a good mike pad less than 20dB, so-so 15dB. You shouldn't often need over 20dB pad... else you may be using poor-choice tools.
Hot condensers should have a -10dB capsule shunt. Use it.
Offline Bassmanster
  • Rarrrawweth!
Re: Mic Pads
« Reply #3 on: September 16, 2010, 07:56:55 am »
Thanks guys.  If I did I would emulate the in/out impedance of Shure's pads, which are published.
Cheap condensers, no pad.
I think I'll try using a buzz box for the time being and turning the amp down.  I can also hack the built-in -14 pad in my mic pre (Hamptone) to something higher (er, lower).
Offline RicharD
    • Toxic Water
Re: Mic Pads
« Reply #4 on: September 16, 2010, 10:38:25 am »
Sometimes I think I'll never figure this stuff out.  Here's a good link:
http://www.uneeda-audio.com/pads/
Looks like the standard is a -20dB "U" pad using 2 - 680 ohm and 1 - 150 ohm resistor.  Meanwhile my project is completely backasswards.   :BangHead:
Offline Bassmanster
  • Rarrrawweth!
Re: Mic Pads
« Reply #5 on: September 16, 2010, 10:57:45 am »
I found some online java applet calculators for H pads.  You input the attenuation, input and output Z and it gives you the five resistors.  So that will come in handy if I decide to do it.
I should have just got the resistor-based step gain controls on my pre, but it was more money.
