September 19, 2026, 01:48:09 pm
Hoffman Amps Forum image Author Topic: No preamp voltages on fender bassman 135 b  (Read 6018 times)
Offline stantheman
« on: September 18, 2010, 03:23:49 pm »
Hello,  I am hitting my head against the wall on this repair project.  This is a bassman 135b head.  Lights up. no sound.  No shorts with current limiter. 530 dc on b+ rail nothing coming out of the power supply filters. OT all caps screen grid and socket resistors changed out.
I get voltage readings from the power tube pins but nothing on the preamp tubes.  I have fixed a lot of amps but this one has me beat. I resoldered all of my solder jobs and cannot find the culprit yet.   Here are my voltage readings (filament voltages ok)
sjbassman1.htm
Offline stantheman
Re: No preamp voltages on fender bassman 135 b
« Reply #1 on: September 18, 2010, 03:59:45 pm »
Holy crap.....
2.7 k 10 watt resistor totally open.... Sometimes I need an outside opinion to get my focus.
I will replace and thanks.
« Reply #2 on: September 18, 2010, 06:27:11 pm »
That 2.7K resistor must take a real beating. Probably would sound better as well with a real choke in that spot
Offline stantheman
« Reply #3 on: September 19, 2010, 01:11:28 am »
noted:
will do.
My bass player played the amp at a gig. Worked well.
Thanks again.
