September 19, 2026, 08:12:59 am
Hoffman Amps Forum image Author Topic: Choke, need info???  (Read 6948 times)
Offline sawdust
  • tube amps are cool
Choke, need info???
« on: September 19, 2010, 10:14:45 am »
I have a choke with these markings; 320319-2; 806537. It measures 127 ohms and weighs about 1 lb. Anyone recognize the manufacturer and any specs?
Thanks in advance,
Dave
Dave in Dacula
Offline Tiny_Daddy
  • Get your Amp N Gear!
Re: Choke, need info???
« Reply #1 on: September 19, 2010, 10:49:59 am »
Can you measure the inductance?
Offline sawdust
« Reply #2 on: September 19, 2010, 11:50:32 am »
No, I have no way to do that, my DMM doesn't measure inductance.  :sad:
Dave
Dave in Dacula
Offline stingray_65
« Reply #3 on: September 19, 2010, 11:59:08 am »
I could not find much except that 806 refers to Gordos in NJ.
I do not know what they built but they did remove their EIA code in 1975.
Could you post a pic or give us the dimensions?
We may be able to "guesstimate" values for you.
Where did you acquire the choke?
I'm making the assumption that you are simply looking for parameters where you could use this choke in an amp and it's history isn't all that important.
Ray
Offline tubesornothing
« Reply #4 on: September 19, 2010, 04:22:20 pm »
I actaully have the same problem.  I hunted around on the net for some method by which I could measure inductance.  Here is what I found:
1) get a 2k 10W resistor, measure its resistance accurately
2) hook the resistor in series with the inductor
3) apply 120VAC to the resistor/choke
4) measure the voltage drop across the resistor (Vr) and the choke (Vi)
Calculate the current through the resistor  (Ir = Vr / R)
Calculate the reactance through the choke (Z = Vi / Ir)
Calculate the inductance (H = Z / (120 * pi))
Offline Merlin
« Reply #5 on: September 19, 2010, 04:38:13 pm »
That is a fairly abusive test- it is liable to saturate the choke, which would give a false reading. You can do the same test at low voltages though.
Offline stingray_65
« Reply #6 on: September 19, 2010, 04:49:56 pm »
WOW!
I've been hunting for this info for a while!
No more "Best Guesses" for me!
TYVM
Ray
« Reply #7 on: September 19, 2010, 05:01:12 pm »
Thanks Merlin,
I measured 3 chokes, 2 were known, and one unkown.  Both methods gave similar results (+/-  1/2H) but the first method was nasty to one of my chokes - just really vibrating, not to the point of smoking.  For your method I used 25VAC - more suitable I expect?
« Reply #8 on: September 19, 2010, 09:38:14 pm »
I was gonna say.... 120VAC!!??
6V (your nearest filament winding) ought to be ample, give good readings, not over-strain any tube-suitable chole, and be a lot less lethal to you.
Use a 1K resistor. 1/2W 20% is fine, this isn't watchmaking. A good choke will take "most" of the AC voltage, so read the voltage across the resistor. 3V-2V may be a good rough filter; Fender often used such iron. 1V or less across the resistor is a high inductance for filtering; VOX did a few this way.
None of these methods, no simple method, will determine the DC current handling. You may read the DC resistance, multiply by your expected current squared, and determine the internal heat caused by DC current. Ponder whether that much heat is reasonable in that size lump. (Or compare with Hammond's chokes.) But something made in NJ in 1973 may not even be a DC-rated choke.... AC-only chokes are used for several things, from telco filters to motor protection.
