September 08, 2026, 04:40:34 pm
Hoffman Amps Forum image Author Topic: Question about 250 dual pot on tos  (Read 6669 times)
Offline 67polara
  • Here is my Guild 67 polara
« on: September 25, 2010, 10:32:27 am »
Hello:
Having a problem finding a 250k dual pot for the master volume on the TOS.  Would it be OK to parallel 330K ohm resistors with the 1 Meg dual pots to bring it to the correct value?
Tony
« Last Edit: September 25, 2010, 10:38:14 am by 67polara »
Re: Question about 250 dual pot on tos
« Reply #1 on: September 25, 2010, 11:05:55 am »
Until I got both TOS amp switched over to VVR, I used a 500k dual gang pot with 470k resistors and that seemed to do fine.
I also currently have that 500k dual pot/470k resistors on my Tweed OD lite & it works fine on there.
I'm thinking your plan with 1M and 330k should work fine. You could also use 270k instead of 330k.
Offline 67polara
« Reply #2 on: September 25, 2010, 11:18:34 am »
Will do thank you.  Any wattage concerns with the resistor, 1/2 watt ok?  A 270k calcs out to 212.6k and a 330k is 248k. Are you sure I should use the 270K?  What about the Resistance not matching between the two pots due to tolerances?  Should I put a trimmer on one side to match them?
Tony
« Last Edit: September 25, 2010, 11:27:43 am by 67polara »
Offline Geezer
« Reply #3 on: September 25, 2010, 11:40:34 am »
Offline toobzilla
« Reply #4 on: January 30, 2025, 09:12:43 am »
Hello:
Tony
try hoffman amps.
