September 14, 2026, 10:10:22 am
Hoffman Amps Forum image Author Topic: New high output LED  (Read 27218 times)
New high output LED
« on: September 29, 2010, 12:21:37 pm »
I added a High output LED to my web store
http://www.hoffmanamps.com/MyStore/catalog/parts20.htm
Drive them somewhere around 3.6 volts at 20 to 30 milliamps
Here's a pic of one
Only 5mm in diameter and 14000 mcd
This is a pic of the LED being run at 25 milliamps on the bench
It blinded the camera
Note that I put 3 of these in series to test running them on 12 volts
Can't remember what current limit resistor I used, but they worked great and would not suck much current from a emergency battery.
This page will help you calculate the current limit resistor
there are two different calculators on this page
http://www.el34world.com/php/LedCurrent.htm
« Last Edit: September 29, 2010, 12:24:43 pm by EL34 »
