August 29, 2026, 08:50:39 am
Hoffman Amps Forum image Author Topic: Where can I order a transformer with the following specs...  (Read 7087 times)
Offline bruno
  • got to love that glow
« on: October 05, 2010, 05:23:40 pm »
I'd like to know if anyone can help me finding a place where I can order a transformer with a 180V-0-180v high voltage tap, 6,3V tap for heaters, 5v tap for rectification and 250ma current handling.
Offline phsyconoodler
Re: Where can I order a transformer with the following specs...
« Reply #1 on: October 05, 2010, 06:06:20 pm »
Unknown.What are you building with that?That low a voltage and that high a current handling smells class A something with 4 power tubes to me.
  Hammond will make one for you.Not that expensive at all.
Offline triode
  • Use the silver solder
    • TheAirtightGarage
« Reply #2 on: October 05, 2010, 06:08:00 pm »
Is this close enough...
Hammond 263CX I think they are about $60 retail.
116VA
sec. 180-0-180, DC ma 250,
Fil. #1(rectifier) 5.0v @ 3a ct
No 6.3V, but a filament transformer is pretty small (think fender choke size).
A 4A 6.3V from Hammond is like $12, so your total is about $80 with shipping
perhaps?
That is all I can think of, other than calling Heyboer and saying "I need a transformer
that has..."   Hrmmm, for a single from Heyboer, the two trannies from Hammond will
probably be cheaper, unless you want 10 or more of them.
Just my $0.02.
Offline FYL
Offline bruno
« Reply #4 on: October 05, 2010, 07:27:26 pm »
Hi guys, thanks for the answers...
Phsyconoodler, it will be used on a two 6v6s, push-pull class A output stage (I'm ordering a high current handling in case I end up going with 4 output tube stage). Not sure what the pre amp will be yet, just messing around with ideas, until I get something I like.
Well I had looked at the 263cx and what made me backup was the lack of a 6.3v tap, but I didn't even remember I could order a separate 6.3v transformer, I guess I might just do that.
I've also looked at edcor, but couldn't find what I wanted, although I know they make them, but it would have to be a custom order, just like heyboer.
Thanks guys
« Last Edit: October 05, 2010, 07:29:49 pm by bruno »
Offline Shrapnel
« Reply #5 on: October 05, 2010, 09:55:52 pm »
Try Edcor
http://www.edcorusa.com/Home.aspx
Edcor = American made.
Edcor charges a 1x fee for a custom build... but after that if you need even just one more with those specs in the future, that custom build fee is history.
-Later!
Offline FYL
« Reply #6 on: October 06, 2010, 08:07:34 pm »
No 6.3V
You can most of the time pick instead a 300-series with filament windings, a larger core sized for 50 Hz and world voltages (100 to 240V pri). But alas not here...
« Reply #7 on: October 06, 2010, 09:47:52 pm »
http://www.edcorusa.com/Products/ShowProduct.aspx?ID=500
no 5V sec. request they wind it with one.
probably drive the cost up 5-10$ with the additional winding + the 40$ design and setup fee.
« Reply #8 on: October 07, 2010, 12:36:52 pm »
Two 6V6 250V 10K can run Class A, or so close that who cares? Plate current rise is only 10%; that's far closer to A than to B.
180VAC with bottle rectifier will be much less than 250VDC. If you double-up the SE 180V condition, 11K load, you get like 4 Watts output. Seems like a lot of trouble for four watts. It may be easier to run 280V 20K load, get 7 Watts of pure-A output.
