September 16, 2026, 02:02:56 am
Hoffman Amps Forum image Author Topic: 5E3/5G9 Hotswitch mod  (Read 5568 times)
Offline deqqed
« on: October 07, 2010, 02:45:59 pm »
Howdy ya'll--I'm going to mod my upcoming 5G9 build to drop the mic channel and add Doug's hotswitch mod (http://www.el34world.com/projects/hotswitch.htm), does this implementation look OK?
I'm planning on experimenting a bit with the values for Rc and Rg.  Any thoughts?
thanks,
david earl
Re: 5E3/5G9 Hotswitch mod
« Reply #1 on: October 07, 2010, 04:45:14 pm »
That looks like it's drawn correctly to me.
« Reply #2 on: October 07, 2010, 10:29:02 pm »
I'd be inclined to make both Rks in V1 1k5 to begin with.
As for the grid load resistor after V1'b', that is in parallel with the V/TS - so if you may it smaller, everything will be more lossy.
Offline deqqed
« Reply #3 on: October 08, 2010, 12:40:20 pm »
Thanks for the responses!
You know, I put that load resistor there because Doug's circuit had it--but it's not completely clear to me if it's necessary here.  What would be the effect of omitting the load resistor?
thanks,
david
Offline topbrent
  • In pursuit of more cowbell...
« Reply #4 on: October 08, 2010, 01:36:16 pm »
You might take a look at Doug's Stout.  It is a simple amp with a similar architecture.
