September 15, 2026, 04:20:01 am
Hoffman Amps Forum image Author Topic: Substitute 6V6s for 6L6s?  (Read 6730 times)
Offline firemedic
« on: October 11, 2010, 08:15:02 pm »
Are there any problems with using 2 6V6s in a 2-6L6 amp? I know there will be an OT impedance mismatch but I run the 6L6s in triode mode all the time, & it sounds fine.
Re: Substitute 6V6s for 6L6s?
« Reply #1 on: October 11, 2010, 08:24:07 pm »
Cathode biased or fixed bias?  If fixed bias, you'll need to rebias.   And ...... What is the voltage on the plates?
Take a look at the voltage rating for JJ 6V6's.
Offline firemedic
« Reply #2 on: October 11, 2010, 08:28:57 pm »
It's cathode biased, @30v on the cathode, plate voltage is @ 400 to ground which I believe makes the functional plate voltage @370. Either way I think the 6V6 can handle the plate voltage. And I guess I did mean "would they work, after changing the bias resistor", which sort of goes without saying.
« Reply #3 on: October 12, 2010, 02:25:46 pm »
NOS tubes may be sketchey but newer types should be fine.
Offline firemedic
« Reply #4 on: October 12, 2010, 06:29:11 pm »
Thanks, I thought so but there's an ocean of things I don't know about these things.
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #5 on: October 12, 2010, 10:03:24 pm »
The JJ 6V6S seems plenty stout and I have installed it in 6L6 amps with 2 speakers connected in series for a quieter sound.
