June 12, 2026, 07:38:56 pm
Hoffman Amps Forum image Author Topic: Capacitance showing on plate reading  (Read 6254 times)
Offline musicfixerupper
« on: October 12, 2010, 10:02:12 am »
Hello all, while measuring plate voltage on an EL84 I can't get a reading and capacitance "uf" appears on the DMM screen. would this just be a bad solder joint?
Offline FYL
Re: Capacitance showing on plate reading
« Reply #1 on: October 12, 2010, 10:11:07 am »
Is your DMM set for voltage measurements? On which scale? Do you use the right sockets for your test leads?
« Reply #2 on: October 12, 2010, 10:19:33 am »
Yes everything is hooked up properly. One of the power tubes read good but the other get the wonky reading.
« Reply #3 on: October 12, 2010, 10:22:56 am »
Which meter? Got fresh batteries? Can you try another meter?
« Reply #4 on: October 12, 2010, 10:42:29 am »
Again, I'm still getting a good reading on one power tube.
« Reply #5 on: October 12, 2010, 10:48:17 am »
OK, I got that. What about my ???s
« Reply #6 on: October 12, 2010, 11:04:46 am »
oops sorry, Wavetek meterman 35xl, batteries are fresh and its the only meter i have.
« Reply #7 on: October 12, 2010, 11:23:11 am »
I occasionally get bad readings on pa tube plates too using a Fluke 87V. Many times the tube will start oscillating. It is usually caused by a bad probe connection to the tube pin. Sometimes you can see a small blue arc at the probe tip. I now use meter leads with needle point probes that seem to work better. Try connecting the probe to the socket pin with a gator clip lead BEFORE turning on the plate voltage. Does that help?
Are you having any problems with the amp other than being able to measure the plate voltage?
« Reply #8 on: October 12, 2010, 12:41:14 pm »
Nope same result. The amp also starts a hum when the probe is on the plate.
« Last Edit: October 12, 2010, 01:03:59 pm by musicfix »
« Reply #9 on: October 12, 2010, 01:13:27 pm »
I removed the phase inverter tube and i was able to get a reading on the power tube. Things get haywire again after i plug the phase inverter tube in. Different PA tubes didn't help
« Reply #10 on: October 12, 2010, 01:44:46 pm »
Tell us about the amp. New build? Does it work? Got a schematic?
« Reply #11 on: October 12, 2010, 02:43:15 pm »
Its actually a fender blues JR that i am working on. I am going to clean up the lead dress and see if that makes a dfference.
