August 29, 2026, 08:52:57 am
Hoffman Amps Forum image Author Topic: OT Question  (Read 5409 times)
OT Question
« on: November 06, 2010, 02:05:21 am »
Hi guys, Putting a little amp together. I've got a magnetic components 15w SE OT and it has two primary taps 5K and 8K.The amp has a single 6L6GC .What tap shall i use?? Thanks
Offline LooseChange
    • Fix Your Darn Amps
Re: OT Question
« Reply #1 on: November 06, 2010, 05:48:30 am »
6L6=5K, 6V6-9K.  But try them both for tonal excitement.
Call me Dan
www.fydamps.com
Re: OT Question
« Reply #2 on: November 06, 2010, 04:50:46 pm »
Thanks for the reply LC. So it might be useful to add a switch to allow the use of both types of tubes?? Would the existing resistors/caps allow for a simple tube change?? Thanks
Re: OT Question
« Reply #3 on: November 06, 2010, 08:55:22 pm »
For 6V6 6L6 EL34: ten times the cathode resistor.
5600 ohm load.
_IF_ the cathode resistor is correctly choosen!!
Or--
You got like 450V B+. Say 400V across the tube.
6L6GC is rated 30W. Pretend this is safe. 30W/400V is 75mA. 400V/75mA is 5333 ohms. Your pentode's optimum power-output load will be in-sight of this value.
This is all scatter-shot. Transformer is just a lever. The real load is the speaker. An "8 ohm" speaker will be 7 ohms near 400Hz, 9-15 ohms over much of the guitar band, and 50 ohms at bass resonance.
You can't hurt an SE amp by trying different impedances.
This amp is NOT suitable for happy 6V6. Connect pin 1 to pin 8 and try EL34.
Re: OT Question
« Reply #4 on: November 07, 2010, 12:37:04 am »
Thanks guy's, ive just updated the schem.
