August 29, 2026, 08:53:42 am
Hoffman Amps Forum image Author Topic: A new question about PT & OT - What happen using Ferrite Cores ?  (Read 6399 times)
« on: November 07, 2010, 06:10:30 am »
Yesterday I was to a Hamfest
at the flea market  I noticed some cores for transformers in ferrite
what will happen building PT and OT with this particular material ??
Very curious about
have you some news about ?
Kagliostro
Offline FYL
Re: A new question about PT & OT - What happen using Ferrite Cores ?
« Reply #1 on: November 07, 2010, 06:37:18 am »
Ferrite cores are mainly used for high frequency applications (HF by audio standards, > 20 KHz).
« Reply #2 on: November 07, 2010, 07:48:46 am »
Hi FYL
Ok they are used mainly for High Frequency applications
But what can we aspect
in the use for PT at 50 / 60 Hz
or as OT in guitar amp ?
Assuming the use in an OT
this OT will have some "special features"
as large frequency response ?
Kagliostro
Offline FYL
« Reply #3 on: November 07, 2010, 08:00:50 am »
NiZn ferrites show poor permeability, typically below 800, making them very poor candidates for 50/60 Hz ops. Good old steel lams are much better - and cheaper too.
Ditto. Poor LF capabilities.
« Reply #4 on: November 07, 2010, 10:20:43 am »
thanks again  :smiley:
Kagliostro
« Reply #5 on: November 08, 2010, 12:34:12 am »
Thin iron has large losses at and above the top of the audio band.
Powdered iron has low losses into the radio bands, but 1/100th the inductance of thin iron, meaning a VERY large transformer.
Ferrites give more inductance than old powdered iron, but still not enough to be very practical at low audio frequencies.
Iron (sliced thin and cut with Silicon) gives the most energy storage per pound and per dollar. That makes it the best material for low frequencies.
Some newer stuff, not iron and not ferrite, amorphous, gives inductance and energy storage within sight of iron. Some very rich hi-fi hobbyists use it.
« Reply #6 on: November 08, 2010, 02:00:55 am »
Hi PRR
Thanks also to you
your infos has furthermore clarified the matter  :smiley:
Kagliostro
