August 29, 2026, 08:52:44 am
Hoffman Amps Forum image Author Topic: Using resistor for speaker load  (Read 5045 times)
Offline jeff
  • Need input
« on: November 07, 2010, 03:41:55 pm »
 I was reading about making a line out for a Champ, basically a voltage divider, to plug to the input of a bigger amp so you can crank the smaller amp to power tube distortion and use the bigger amp to get the volume you want. Could you use a 4 ohm resistor instead of a speaker?
Really what I getting at is building a preamp with power tube distortion.
I found some resistors that are 8 Ohm 20 watt non inductive power resistors. I know a speaker has an inductive resistance but Would 2 of these in parallel work?
Re: Using resistor for speaker load
« Reply #1 on: November 07, 2010, 04:32:51 pm »
Hey Jeff - sure the two 8's would work, but take a look at this link and look at the TT PoS50 . It has a line out built in.
http://www.tube-town.net/diy/tt-pos/tt-posx-en.html
you could just make a simple one with only your two resistors in it.
« Last Edit: November 07, 2010, 04:35:17 pm by mresistor »
