August 29, 2026, 08:54:10 am
Hoffman Amps Forum image Author Topic: I got another console tube amp coming...  (Read 5534 times)
Offline softwarejanitor
« on: November 09, 2010, 08:48:58 pm »
I won another Motorola tube amp from an old console record player in an eBay auction last week...  It should be here in the next couple days...  Its an HS-475 which is a 1956 model.  It uses 5Y3 rectifier, two 6V6 power tubes and the pre-amp section is 6AU6, 12AU7, 12AU7 driver/inverter.  I've got another HS-475 I've already converted to a guitar amp with two 12" Motorola Golden Voice branded Heppner speakers in a tweed covered combo cabinet I built.  This one is coming with a Jensen 15" speaker and I am planning to build a tweed covered combo cabinet for it.  I will mod the circuit similarly to the other one I have...  removing the "loudness" compensation circuit from the back of the volume pot, replacing the feedback resistor at R26 from 5.6k ohm to 22k ohm and swapping out the 2nd pre-amp tube from a 12AU7 to a 12AT7.  I'm planning to take pics of the conversion process and building the cabinet as I go along this time and post them.
Re: I got another console tube amp coming...
« Reply #1 on: November 10, 2010, 05:14:27 am »
I'll look forward to seeing the pictures of your amp conversion. Thanks for being willing to share that.
« Reply #2 on: November 10, 2010, 09:14:46 pm »
I received the HS-475 chassis and Jensen 15 today.  They look even better than I expected.  Other than a little dust they look virtually brand new.  I stopped by Fry's today and picked up the rest of the parts I need for the guitar amp conversion...  8' 3 prong power cord, 250V ON-OFF toggle switch, 250V fuse holder, a pack of 2A fuses, a couple packs of 1/4" mono jacks and a pack of 1W 22K ohm resistors.  I will start work on the conversion later this week or this weekend and will be taking pics of the process to post.  After that I will start on building the cabinet and take pics to post of that as well.
