August 29, 2026, 08:53:42 am
Hoffman Amps Forum image Author Topic: Roland Jazz Chorus 120  (Read 5691 times)
Offline punkykatt
« on: November 16, 2010, 06:41:19 pm »
Hello all, Got a Roland Jazz Chorus 120 on the bench. Had to do only minor repairs to get her running. One of the two speakers has a open voice coil. Can`t find any ID numbers anywhere on the speakers. All it says on the magnet is Roland ,heavy duty transducer , improved cone design for better damping effiecency, reliable fidelity at peak capacity, high sensitivity at max output. Made in Japan.  Can`t find much info on the net. Would anyone here know what would be a good /close to original replacement speaker?
Thanks  Punky
Offline Tiny_Daddy
  • Get your Amp N Gear!
Re: Roland Jazz Chorus 120
« Reply #1 on: November 16, 2010, 07:54:51 pm »
I would install a pair of Jensen ceramic MOD speakers and color it done.
Offline punkykatt
« Reply #2 on: November 16, 2010, 08:08:19 pm »
Thanks TD, Should I get the 70 watt or go with the 110 watt?
Offline Tiny_Daddy
« Reply #3 on: November 16, 2010, 08:30:05 pm »
I am thinking those are 12 inch speakers? According to Roland the amp is 60 + 60 Watts so go with the MOD12-70. Also the weight is half of the MOD12-110.
Offline punkykatt
« Reply #4 on: November 16, 2010, 10:10:16 pm »
Thanks. I will inform the owner of those replacements.
