August 29, 2026, 09:46:29 am
Hoffman Amps Forum image Author Topic: tone stack cap voltages  (Read 9165 times)
Offline nateflanigan
« on: November 17, 2010, 09:38:59 pm »
What voltage should tone stack caps be?
Re: tone stack cap voltages
« Reply #1 on: November 17, 2010, 09:43:55 pm »
That depends on the circuit. 500V will cover most all circuits.
« Reply #2 on: November 17, 2010, 10:26:56 pm »
In the Fender stack, the two big caps MUST block the no-load supply voltage. 400V is often OK for many years. The pFd cap on Treb has negligible voltage, but in that value you can get 500V as cheap as any other.
Offline The_Gaz
« Reply #3 on: November 18, 2010, 01:50:44 am »
You could always put  high voltage (500vdc or so) cap before the tone stack, which would allow you to use low voltage caps in the stack. The cap should be at least .022 uf or bigger if you don't want to change normal frequency response as if the cap wasn't there. This may seem economical, but it's really not - modern caps at those values are cheap. Just an option if you are eager and have some low voltage caps in the right values on hand.
« Reply #4 on: November 18, 2010, 07:09:09 am »
thanks guys.  It's for some AB763 tone stack tweaking that fresh_start has been helping me with.  I ordered a 100v cap by mistake.  It's such a drag when you're like one part short of finishing something up.
« Reply #5 on: November 18, 2010, 12:33:20 pm »
Ditto;  except for the decimal point.  Per the Rule of Tens, that hi voltage cap needs to be at least 10X larger than the largest cap in the tonesatck = .22 or .47uF.
