August 29, 2026, 08:54:10 am
Hoffman Amps Forum image Author Topic: 12AX7  (Read 7652 times)
12AX7
« on: November 17, 2010, 11:16:30 pm »
Hi again, I am of the understanding that the two halves of a 12AX7 are the same, yet i have seen a couple of schems that show the pin connections to be a particular way but to run the connecting wires it would be better to do the opposite. Thanks
Offline rafe
  • I have tube amps
Re: 12AX7
« Reply #1 on: November 17, 2010, 11:41:36 pm »
or you could do a 180 on the socket?
Rafe
Re: 12AX7
« Reply #2 on: November 18, 2010, 12:13:11 am »
Thanks rafe, You are correct , not knowing the actual layout of these builds it may just as simple as that. So i am correct, their is no difference. Thanks
Re: 12AX7
« Reply #3 on: November 18, 2010, 12:39:41 am »
That's a good way to mis-wire something, and, in an upside-down chassis, make it easy to bend pins mis-inserting the tube somewhere down the line.
Offline LooseChange
    • Fix Your Darn Amps
Re: 12AX7
« Reply #4 on: November 18, 2010, 04:48:32 am »
If I am understanding you correctly... The 12AX7 pin order is the same either way.
Pins 1, 2 and 3 are the same as pins 6, 7 and 8. When planning a layout I'll always consider the positioning when running my wires.  I would leave all tubes positioned the same way and just re-number the schematic.
Call me Dan
www.fydamps.com
Re: 12AX7
« Reply #5 on: November 18, 2010, 04:58:11 am »
Thanks LC, done that. Got quite a involved build with the little booga and got a spare 1/2 12AX7 and don't know what to do with it.
Offline LooseChange
Re: 12AX7
« Reply #6 on: November 18, 2010, 05:25:26 am »
Maybe parallel the other half?
Call me Dan
www.fydamps.com
Offline FYL
Re: 12AX7
« Reply #7 on: November 18, 2010, 07:05:27 am »
"With Vf applied to pins 9 and 4+5 and the centre tap of the heater transformer connected to earth, the triode section connected to pins 6,7 and 8 is the more favourable section of the triode with respect to hum", from the '54 ECC83 Philips datasheet.
Offline jeff
  • Need input
Re: 12AX7
« Reply #8 on: November 19, 2010, 12:47:42 pm »
 I don't know how much of a real difference it makes but I always use the 6 7 8 section as my first gain stage, especally in a high gain build. The 1 2 3 stage is said to be noisier so by using the 6 7 8  stage first your second stage amplifies less hum.
Re: 12AX7
« Reply #9 on: November 19, 2010, 03:39:50 pm »
Boy, you guys have got the goods!! This does explain a lot , i did a small build that had the second stage Pins 6,7 & 8 at the input. I just thought it was that way just for ease of wiring.
Can anyone explain why a v1 (12AX7) would have DC power (6.3v ac converted to DC) to the heaters and all the other of the valves AC ??
Offline FYL
Re: 12AX7
« Reply #10 on: November 19, 2010, 03:44:30 pm »
Input signal is app. 100 mV, V1 gives 30 or 40 dB of gain in common amps, any heater-induced hum can be very noticeable. V2 and others work at much higher levels and are less susceptible to hum. Power tubes don't need DC heaters - common mode noise is nearly eliminated at the OT.
Re: 12AX7
« Reply #11 on: November 19, 2010, 04:38:13 pm »
Thanks again, I have a project in the planing stage that is the dual rectifier peramp that has V1 dc heaters . I'll see how it goes with AC and convert it if need be. Thanks
