August 29, 2026, 08:50:09 am
Hoffman Amps Forum image Author Topic: A weird noise  (Read 6660 times)
Offline Leevi
    • Rikstone
A weird noise
« on: November 24, 2010, 04:05:47 pm »
I'm finalizing my Plexi 50 and I noticed after some hours playing a weird noise that waves.
I thought that it is related to a bad/microphonic tube and changed the preamp tubes but it didn't help.
Any idea what could be a cause?
/Leevi
Offline Voxbox
  • drrun-drrun-drrun diddle-diddle diddle-diddle
Re: A weird noise
« Reply #1 on: November 24, 2010, 04:32:55 pm »
Hi Leevi,
Can you describe what "waves" means in another way?
 :wave: :wave: :wave:
Cheers
everything will be ok
in the end.
if it's not ok,
it's not the end.
Re: A weird noise
« Reply #2 on: November 24, 2010, 04:59:23 pm »
Maybe you have a power tubes that is going bad. Volume drop and nasty distortion? Intermittant?
Offline Leevi
    • Rikstone
Re: A weird noise
« Reply #3 on: November 25, 2010, 12:11:16 am »
The intensity of the noise is varying randomly
I'm thinking a possibility that the amp works as a radio receiver which
causes the noise?
/Leevi
Offline Voxbox
Re: A weird noise
« Reply #4 on: November 25, 2010, 07:16:02 am »
What kind of noise is it?
Hiss, crackles, popping?
in the end.
if it's not ok,
it's not the end.
Offline Leevi
    • Rikstone
Re: A weird noise
« Reply #5 on: November 25, 2010, 09:10:06 am »
It's more like hiss
/Leevi
Re: A weird noise
« Reply #6 on: November 25, 2010, 09:41:24 am »
Is this what you could be hearing! :smiley:
Offline Leevi
    • Rikstone
Re: A weird noise
« Reply #7 on: November 25, 2010, 11:58:36 am »
Download and listen
Works at least with VLC player
http://www.kolumbus.fi/risto.kivioja/RikstoneAmps/PlexiHiss.MP4
/Leevi
Offline FYL
Re: A weird noise
« Reply #8 on: November 25, 2010, 02:40:05 pm »
Download and listen
Interesting. Looks and sounds a lot like the signal I got from PSR B0823+26 a while ago.
Re: A weird noise
« Reply #9 on: November 25, 2010, 05:29:13 pm »
This sounds exactly like a bad preamp tube. I have had this issue the past 2 weeks using some old tubes in one of my amps. Replaced the bad tube or tube socket and all should be quiet
Offline Leevi
    • Rikstone
Re: A weird noise
« Reply #10 on: November 25, 2010, 06:03:37 pm »
That was also my first guess but after I changed the preamp tubes one by one
the problem was still there.
This makes it more difficult to troubleshoot:
I added today 1 Ohm resistors to the cathodes of the power tubes and started to test the amp.
First I listened the noise but after one minute it suddenly disappeared.
OK, I thought that maybe the cathode resistors have some relation to the problem and made another
test by removing the cathode resistors. I didn't hear the noise any more and now my problem is to
get it on again.
/Leevi
« Last Edit: November 26, 2010, 12:13:20 am by Leevi »
Offline Leevi
    • Rikstone
Re: A weird noise
« Reply #11 on: November 27, 2010, 11:00:20 am »
I had a similar problem in another amp and I succeeded to found the cause for the problem.
There was a coupling cap (47n going to treble pot) which did't work properly.
It allowed DC go trough and had damaged the treble pot. This was the first time
I found a new Silver Mica cap behave like that.
/Leevi
