August 29, 2026, 08:50:42 am
Hoffman Amps Forum image Author Topic: Fender grid caps  (Read 4331 times)
Offline J Rindt
Fender grid caps
« on: November 29, 2010, 11:43:51 pm »
Each 6V6 grid has a 1200pf cap to ground. Can you guys tell me what they do exactly...?
Thank You
http://www.el34world.com/charts/Schematics/files/fender/deluxe_reverb_boost_schem.pdf
Offline chocopower
Re: Fender grid caps
« Reply #1 on: November 30, 2010, 02:48:15 am »
Some kind of cure for oscillations.
Those caps send to ground the high treble frecuencies.
With a clean layout, they are not necesary in that amp.
David
Offline LooseChange
    • Fix Your Darn Amps
« Reply #2 on: November 30, 2010, 05:35:42 am »
When working on an amp that has these, I usually lift one at a time to see if I can remove them. So far I have not had an amp that had a problem with these removed. (So far.)
Call me Dan
www.fydamps.com
