August 29, 2026, 08:51:18 am
Hoffman Amps Forum image Author Topic: OT Impedance match  (Read 5984 times)
Offline LooseChange
    • Fix Your Darn Amps
OT Impedance match
« on: November 30, 2010, 05:33:11 am »
I get this mixed up all the time...
A 6V6 pushing an OT with 9K primary, secondary 8 ohms into an 8 ohm speaker.
Switch out the 6V6 to a 6L6.
What secondary (16 ohm or 4 ohm) do I use to best match the 6L6 with the 8ohm speaker?
Thanks!
Call me Dan
www.fydamps.com
Re: OT Impedance match
« Reply #1 on: November 30, 2010, 05:50:11 am »
I've used a 16 ohm with 5881/6L6 with an Emminence 8 ohm speaker for a number of yrs now & it sounds fine to me.
Hopefully someone will chime in that actually knows if that's correct.
Offline LooseChange
« Reply #2 on: November 30, 2010, 06:31:53 am »
Your OT has a 9K primary??
Actually the tone is not the issue. The amp sounds great with any impedance choice.
Just looking for the "proper" match. Thanks!!
Call me Dan
www.fydamps.com
« Reply #3 on: November 30, 2010, 07:20:12 am »
Sorry about that.  No, the OT primaries on the two amps I've done this with are 6.6k & 7.6k.
Offline Dave
« Reply #4 on: November 30, 2010, 07:22:53 am »
4 ohms.
If you pulled two tubes out of a twin reverb, you would run an 8 ohm load. Same if you replaced all 4 6l6's w/ 6V6.
You are going the other way. So, 8 ohms for 6V6's becomes 4 ohms for 6L6.
Dave
« Reply #5 on: November 30, 2010, 08:10:35 am »
A 2:1 or 1:2 mismatch is considered generally acceptable: e.g.: 4Ω speaker off an 8Ω tap, and vice-versa.  Caveat:  Marshal's are said to be particularly fussy about this.  My SF Princeton was hotrodded with 6L6's, which mismatches the primary OT 1:2; this makes the 8Ω secondary 4Ω.  It drove an 8Ω speaker.  Another 1:2 mismatch on the secondary side.  It worked fine for hours on end, and sounded so good someone insisted on buying it.  I A/B'd 4Ω vs. 8Ω impedances with an impedance matching tranny to convert the now 4Ω tap to 8Ω, to match the speaker.  It sounded good, though a little different, either way.
Ditto to Dave arithmetically.  A tranny performs simple arithmentic.  (How it does this and proper design are too complex for me, but the result is simple).  6L6's have 1/2 the plate impedance of 6V6's.  So, if you halve the impedance on the primary side then you automatically halve the impedance on the secondary side.  The 8Ω tap becomes a 4Ω tap.
