August 29, 2026, 08:53:42 am
Hoffman Amps Forum image Author Topic: I forgot to unhook my jumper to drain the caps......  (Read 7071 times)
Offline CBD1964
« on: December 07, 2010, 08:43:38 pm »
I for got to unhook my jumper when I drained the caps and turned on the amp.
I replaced the one resistor that I noticed was fried.
The amp will power on but is very low volume and distorted.
Please help. what should I start checking first?
Re: I forgot to unhook my jumper to drain the caps......
« Reply #1 on: December 07, 2010, 08:57:15 pm »
Which amp? Where did you connect the jumper? Got a schematic?
Offline CBD1964
« Reply #2 on: December 07, 2010, 09:03:08 pm »
Traynor YBA-1  '71
I hooked the jumper from ground to pin 1 of the preamp tube to drain the caps
« Reply #3 on: December 07, 2010, 09:59:44 pm »
Refer to this schematic... http://www.el34world.com/charts/Schematics/files/traynor/traynor_bassmaster_yba1.pdf
Measure voltage at C20, C21, and C22 and also V1-1. What do you get?
Check R8, R31, and R32. What do they measure?
Offline CBD1964
« Reply #4 on: December 07, 2010, 10:11:35 pm »
Thanks....I'll Check and see what I get
Offline LooseChange
    • Fix Your Darn Amps
« Reply #5 on: December 08, 2010, 05:18:43 am »
I wouldn't expect much damage with the jumper connected all the way down stream like that. Sluckey will fix ya'.
Call me Dan
www.fydamps.com
Offline Platefire
« Reply #6 on: December 08, 2010, 10:39:49 am »
Boy I've done that before--a couple of times!!! But I caught it before it did any major damage. Plate
On the right track now<><
Offline CBD1964
« Reply #7 on: December 08, 2010, 03:21:15 pm »
C20, 21, 22   450V
R8 370
it looks like I do not have R31 or it is not where it should be...LOL
« Reply #8 on: December 08, 2010, 03:41:57 pm »
R31 is that 4.7K 1W resistor on the lower left end of the board (end near the cap cans). It looks good but you still need to measure it. I want to know what the resistance value for those resistors is, not the voltage on them.
Sounds like you measured voltages for C20, 21, and 22 with tubes pulled out?
« Reply #9 on: December 09, 2010, 07:54:47 am »
I just realized that the schematic link I posted is not the same as your amp! Your pic shows a bridge rectifier and no choke. That means that all reference designators, ie, R8, R31, and R32, etc., are not valid for this discussion.
Take a look at this pdf. I believe page 7 and/or 8 most closely match your actual amp.
http://www.lynx.bc.ca/~jc/YBA1Schems.pdf
Did you get it fixed yet?
