August 29, 2026, 08:54:11 am
Hoffman Amps Forum image Author Topic: One Tube SE Guitar Amp -schematic here- I have Power Supply & layout questions  (Read 9023 times)
I Need help for Power supply design and whole amp layout
I've find a nice 1 tube guitar amp schematic
http://www.solorb.com/elect/musiccirc/squirrelmonkey1/
The tube is a 6AF11 Compactron ( two triodes and one pentode )
EDIT
http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_1/6AF11.PDF
http://www.nj7p.org/Tube4.php?tube=6AF11
So is possible to have a 1 tube amp  :grin:
My first BIG problem is the Power Supply  :rolleyes:
I can't use the schematic used by the author because in Italy we have 220v
so the original PS is not usable here
Other problem is a layout
I'm able to copy a layout and build an amp
but to me is difficult to draw a layout
I arranged a layout for the amp and a new Power Supply schematic
Can you give a look and revise ?
The red wires are on the other side of the board - the 20uf 20nf cap (green wires) is connected directly to the socket.
I'm very confused about the Power Supply
Questions:
Voltage difference
I have 220v transformers - Must I decrease the voltage till 180v and 175v, voltages that the autor used, or can I assume that those voltage are the voltage obtained with the original 120v-120v/28v Power Transformer used by the autor and I can rise a little the B1+ & B2+ voltages ??
Consumption
As I've 2 x 10VA - 220v/9v transformers, is 10VA enough for that amp or I must use 2 x 15VA transformers ?
Kagliostro
« Last Edit: December 10, 2010, 05:00:37 am by kagliostro »
Be sure you can get that socket in your area.
He has the power stage biased for about 25mA at 180V. 20ma at 200V would be acceptable also.
Preamp stages are 1mA or less each.
Your 220V winding will rectify to 308V DC, a little less because two small transformers. You need to lose 300V-200V = 100V at 25mA. 100V/25mA= 4K resistor able to handle 2.5 Watts of heat. (Your row of 33K is much too much.)
Total power pulled from transformer is 308V*0.025A= 7.7 Watts DC. Your AC VA rating should be 12.3VA. Go ahead and use the 10VA. They will sag but you don't need full voltage. They will run hot but 10VA parts usually won't get hot enough to matter.
Instead of ferrite bead, a 33K resistor will probably work better in this high impedance input.
Rectifier is mis-drawn:
« Last Edit: December 08, 2010, 04:04:14 pm by PRR »
Many thanks PRR
Your explanation about consumption is plenty fine
also MANY thanks for correcting my stupid   :shocked:  PS AC connection  :lipsrsealed:
OK I'll use 4K resistors - ( three or .............. one is enough ??? ) and than a 5K 2W resistor as in the original project (or not ?).
I've the tube, the socket and some other parts.
As the author don't used the 33k input resistor I was thinking he do that as to have max gain at input
so, as I have some ferrite beads, I've think to use one there, for the reasons you well know.
I'll use a more standard 33k resistor as from your council
Kagliostro
« Last Edit: December 09, 2010, 03:39:06 am by kagliostro »
OH OH .............  NO !!   :embarrassed: I was really in a wrong way :embarrassed:
My mind was really out of order
I've read newly all PRR wrote about the calculation of the requested resistor
So, if I'm not wrong, I need a row of two resistors
the first as stated by PRR as to reach B1+ at near 200v
~300v - 200v = 100v  -- than -- 100v / 0.025A = 4K resistor
the second assuming B2+ is right at 175v with a B1+ of 200v
~200v - 175v = 25v -- than --  25v / [EDIT 0.025A = 1K] 0.001A = 25K resistor
are this calculations correct ?
B2+ with an increased B1+ (200v instead of 180v) can be set at 175v or must be set higher ?
see new revised schematic
Kagliostro
« Last Edit: December 27, 2010, 05:45:25 am by kagliostro »
As I discovered that the OT (7kohm/3.5ohm) I have in my junk box can not be used as is demaged
can I use this transformer for this amp ?
http://it.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2106475
http://docs-europe.electrocomponents.com/webdocs/0473/0900766b80473a76.pdf
Kagliostro
p.s.: as it is rated for 40mA DC I suppose that is adequate for a Single Ended amp but not sure about
« Last Edit: January 07, 2011, 01:02:19 pm by kagliostro »
Yes.
The 6AF11 power section is pulling about 25mA, so the 40mA OT rating is fine.
Many Thanks PRR
Kagliostro
