August 29, 2026, 08:50:41 am
Hoffman Amps Forum image Author Topic: A strange Transformer ???  (Read 5157 times)
« on: December 11, 2010, 07:43:20 am »
From an old transistor television I recovered this transformer
220v / 15v
secondary has a section of the wire of 0.035in (0.88mm)
I've seen transformers (PT) with the secondary winding
1) wrapped on the primary
2) wrapped (in a separate neck) near the primary
and OT
3) primary and secondary wrapped alternating each other
this transformer is of the first family but has a big difference
between primary and secondary there are at least 6 mm of free space, only air there (and something that I think is as to control overheat)
Have you never seen something like that ?
which is the reason for that unusual way to wrap windings ?
there are particular advantages to do that ?
If there are advantages why we don't see often this architecture ?
Kagliostro
« Last Edit: December 11, 2010, 07:47:13 am by kagliostro »
Re: A strange Transformer ???
« Reply #1 on: December 11, 2010, 06:54:21 pm »
Somebody was REALLY worried about primary to secondary shorts.
Did not want the TV chassis to EVER be directly connected to the wall-power.
If it was 2V-6V it might be for the 20,000 volt end of the CRT or the HV rectifier. But it's too big, 15V is unlikely, and CRT/HV heat was usually a few turns on the horizontal scan transformer.
Unless there is some unusual situation or law, this construction is just expensive.
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #2 on: December 11, 2010, 08:10:55 pm »
Maybe it was designed for short periods of high current, with forced air cooling. Not enough voltage for arc welding though.... Auto battery charger?
« Reply #3 on: December 12, 2010, 02:11:38 am »
Thanks PRR & Tiny_Daddy
those was a little, "transportable" television but there were no batteries
so
that is the answer
Kagliostro
« Last Edit: December 12, 2010, 02:15:36 am by kagliostro »
