August 29, 2026, 08:50:58 am
Hoffman Amps Forum image Author Topic: Filter choke to replace a power resistor?  (Read 7316 times)
Offline JCSIFU
« on: December 17, 2010, 02:41:14 pm »
Hello,
Can anyone help me?
I have a Yamaha T100 head from the late 80's (Soldano designed) and I am looking to do a mod to the amp where a Filter choke is used to replace the power resistor. The guys at Soldano were nice enough to email back to me that the mod was to replace a 500 ohm power resistor with the choke. How does one go about finding the right replacement choke for the job? I believe it is on the top right corner of the schematic I am tagging on to this post.
thanks,
jc
Offline FYL
Re: Filter choke to replace a power resistor?
« Reply #1 on: December 17, 2010, 03:40:53 pm »
A > 4 H / > 80 mA choke such as the 125C1A sold by Doug
should be fine. Soldano used a 10 H / 80 mA choke.
Offline JCSIFU
« Reply #2 on: December 17, 2010, 05:42:24 pm »
Awesome, thanks.  I'll order it now,
jc
Offline Dave
« Reply #3 on: December 17, 2010, 07:41:20 pm »
How does that Yamaha sound? I've always been curious about those things.
Dave
« Reply #4 on: December 17, 2010, 10:01:42 pm »
The amp will loose some of the Sparkle (Chime) it now has using a choke in place of the resistor
If you use a choke it will sound smoother but you will definatley notice the difference
I like the resistor and the tone it gives in some amps. You just have to try it and see if you like it
Offline FYL
« Reply #5 on: December 18, 2010, 04:34:03 am »
The Yamaha sounds quite like an SLO with a crappy reverb section. Adding the choke brings it closer to the 50/100 sound.
