September 08, 2026, 04:42:19 pm
Hoffman Amps Forum image Author Topic: Converting a Traynor YBA-3 Custom to 6550/KT88  (Read 10234 times)
Offline pbman1953
« on: December 18, 2010, 08:35:08 am »
I'm possibly going to pickup a Traynor YBA 3 Custom soon. I've been reading that it's very easy mod to use 6550's or KT88's
Here's the map-
http://www.freeinfosociety.com/electronics/schematics/audio/traynor_customspecial_yba3c.pdf
There seem to be 3 versions, A,B & C. I won't know until I get it .
But here's a section from the Velvet Black site that has many of the Traynor mod discusions-
Original tube [complement] was three 12AX7s and four 6CA7s that I swapped for 6550s (very easy, just boost bias about ten volts in order to have 30ma idle) Original input resistor was 100k and I changed it for 5.6meg like my Ampeg.
Re: Converting a Traynor YBA-3 Custom to 6550/KT88
« Reply #1 on: December 18, 2010, 02:03:20 pm »
If your Traynor will be a YBA-3A Custom
with 6KG6A tubes, for an easy replacement
I think you can consider to modify it for JJ EL509
http://lib.store.yahoo.net/lib/thetubestore/JJ-EL509-S.pdf
http://thetubestore.com/teslael509.html
Kagliostro
Offline pbman1953
« Reply #2 on: December 19, 2010, 09:25:38 am »
The tube you are refering to is for the YBA-3 A "Super" Custom which is a 250 watts amp
My question is about the YBA-3 A Custom a 120 watter. Cabinet wise they are almost identicle but not under the hood
Stock tube is a 6CA7
« Reply #3 on: December 19, 2010, 12:45:05 pm »
I was confused by reading the above mentioned
I assumed there was only one YBA-3A amp (and that the YBA-3A use 6KG6A tubes)
Sorry for the confusion
Kagliostro
Offline pbman1953
« Reply #4 on: December 19, 2010, 02:18:33 pm »
Traynor called 2 high power bass model with both the sample model name, One as a Custom and the other as a Custom Super
« Reply #5 on: December 19, 2010, 09:02:06 pm »
6CA7 is a USA-marked EL34.
The amp is in-spec for EL34. High-quality guitar-rated EL34 are readily available at good prices, such as here.
While I generally approve of 6550 in HEAVY work, 60W-65W/pair is not too excessive for good EL34. In this range, 6550 will not make more Watts, and may max-out a bit harsher than soft EL34. In heavy use you may be replacing EL34 every few years, 6550 may give a few more years, but the price difference makes the cost/gig about the same (and less than you pay for shirts or strings).
Offline Jazzbass_5
« Reply #6 on: November 27, 2024, 06:30:42 am »
Here's the map-
I know this is an Old Post but I have a yba 3 custom special that I would like to do the 6550 mod to and the links you have posted are no longer valid.
Did you I happen to save them anywhere?.
