August 29, 2026, 08:53:24 am
Hoffman Amps Forum image Author Topic: OHHH NOOO. . . 1967 Marshall 100 watt Super Tremolo  (Read 6078 times)
Offline orfeo
« on: December 23, 2010, 10:44:39 am »
I know, I know, I know I know better. . .  but like an idiot, I plugged in and turned on my 1967 plexi with no speaker cab attached.  When I got no sound, I turned it up and then realized what I did.  Turned it off right away, waited a few breathless moments, and then I hooked up the speaker cab and turned it on. . .
Nothin', no sound now.  I assume I blew the output transformer?  Mercury Magnetics will test my OT for free if I send it to them. . . Am I thinkin' down the right path?
Re: OHHH NOOO. . . 1967 Marshall 100 watt Super Tremolo
« Reply #1 on: December 23, 2010, 10:46:50 am »
Did you check fuses and/or try different tubes?
Is the speaker wires hooked up and you have continuity from the amp head to the cab?
Offline orfeo
« Reply #2 on: December 23, 2010, 11:00:56 am »
I'm at work right now, but I'll try to check those items tomorrow if I can and report back.  If I remember correctly, I did check fuses.  This calamity actually happened a few years ago, and I got so upset that I just packed away the amp in my closet and haven't touched it since.  I actually feel physical pain when I think about it!
« Reply #3 on: December 23, 2010, 12:01:26 pm »
Chances are you probably just popped a fuse, pray for your tubes.  When you do open it up, try to take a look at the transformers.  I've seen a mix of Drake and Dagnall and all Dagnall in the old pre-1969 Supers.  If it has a Drake optx, it will sound a slightly different from a Dagnall.  A little more compressed when opened up.
Good luck!
Offline rafe
  • I have tube amps
« Reply #4 on: December 23, 2010, 03:27:46 pm »
If it was the correct fuse it should have saved it ....I won't tell you why I know that....but there was smoke all over and a stink you won't soon forget
Rafe
